My boss has tasked me with looking at log analyzing tools. He mentioned spunk, which has some inter-connective ability with Nagios. Is there any modules or addons that you guys could suggest for log analyses?
Kind Regards,
Doron
Log Analyzer for Nagios?
Re: Log Analyzer for Nagios?
There are a number of plugins that check log files for regex strings and the like. Additionally, there are walkthroughs for splunk integration on the web. See the links below:
http://exchange.nagios.org/index.php?op ... =check_log
http://splunk-base.splunk.com/apps/2237 ... for-nagios
