404 warnings on web content monitor
We have a specific website content monitor that intermittently gives a "HTTP WARNING: HTTP/1.0 404 Not Found"
However, the page loads fine in a browser, no 404.
We have over a hundred of these running, and this is the only one this happens on.
Any ideas on what the issue may be?
Thanks in advance.
Thanks in advance.
Re: 404 warnings on web content monitor
Also, just an FYI, other sites served on the same server do not experience this, and there is an identical instance of this page running on a different server with no issues.
What is the full check command? When it 404s, does it ever go into a hard state?
check_xi_service_http!-s "UA-39208894-3" -f ok -I 10.1.2.237 -u "/" -p 80!!!!!!!abrist wrote:What is the full check command? When it 404s, does it ever go into a hard state?
No, it never enters a hard state, remains as a "warning".
Can you show us the actual command you are running from the command line, along with the output of it, for example:
[root@testbox ~]# /usr/local/nagios/libexec/check_http -H penguinsunbound.com -s "Penguins" -f ok -I 204.169.120.26 -u "/" -p 80
HTTP OK: HTTP/1.1 200 OK - 23653 bytes in 0.478 second response time |time=0.477644s;;;0.000000 size=23653B;;;0Code: Select all
[root@testbox ~]# /usr/local/nagios/libexec/check_http -H penguinsunbound.com -s "bla-bla" -f ok -I 204.169.120.26 -u "/" -p 80
HTTP CRITICAL: HTTP/1.1 200 OK - string 'bla-bla' not found on 'http://penguinsunbound.com:80/' - 23653 bytes in 0.466 second response time |time=0.466010s;;;0.000000 size=23653B;;;0Be sure to check out our Knowledgebase for helpful articles and solutions!
[root@nagios ~]# /usr/local/nagios/libexec/check_http -H 10.1.2.237 -s "UA-39208894-3" -f ok -I 10.1.2.237 -u "/" -p 80lmiltchev wrote:Can you show us the actual command you are running from the command line, along with the output of it, for example:
[root@testbox ~]# /usr/local/nagios/libexec/check_http -H penguinsunbound.com -s "Penguins" -f ok -I 204.169.120.26 -u "/" -p 80 HTTP OK: HTTP/1.1 200 OK - 23653 bytes in 0.478 second response time |time=0.477644s;;;0.000000 size=23653B;;;0Code: Select all
[root@testbox ~]# /usr/local/nagios/libexec/check_http -H penguinsunbound.com -s "bla-bla" -f ok -I 204.169.120.26 -u "/" -p 80 HTTP CRITICAL: HTTP/1.1 200 OK - string 'bla-bla' not found on 'http://penguinsunbound.com:80/' - 23653 bytes in 0.466 second response time |time=0.466010s;;;0.000000 size=23653B;;;0
Like I said though, if i plug 10.1.2.237 into a browser it returns just fine.
Is the string that is checked part of an ajax response? If so, you may have race conditions with the check and the asynchronous ajax call . . .
No, it's a google analytics code. We use that code to monitor all our sites and this is the only one out of a hundred that has an issue, so I doubt that's the problem.
You try increasing the timeout of the check, add "-t 20" to the check:
This is very strange. Very intermittent. Are you also pinging this host? If so, have you noticed any odd spikes in the response time or a number of soft fails?
-t, --timeout=INTEGER
Seconds before connection times out (default: 10)Former Nagios employee
