Howdi fellas!
I would like to edit the css files and change the word "Alias" to something else. Where are the css files that I need to edit located?
editing xi css
editing xi css
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: editing xi css
Depending on what you would like to change, "and generally making web editing life a bit easier" I'd recommend downloaded firebug for Firefox, it allows you to mouse over objects on your webpage and drill down to what file and directory is loading the displayed information. That would probably be the easiest way to go about finding this information.
Re: editing xi css
Thanks man I have FB already. I just wanted to make sure that there might be more steps, or rather other css pages etc.. to make changes to since xi is a lil complicated. Thanks man! you can lock it.
Proudly running:
Nagios Fusion
Nagios Fusion
Re: editing xi css
Well, I'd always recommend copying the file you are working on just in case you really break something. Wish you the best! As always, we can help fix problems that may arise.
