Nagios status information
y.h
Post by y.h »
I am working on a project that has my computer communicating with an arduino board that reads the sensor output and test it in a C plugin ( http://stackoverflow.com/questions/1767 ... on-it?lq=1) for nagios. My problem is that the status information is always null. My plugin is in the lib"/usr/local/nagios/libexec" In commands.cfg I added the following:
    command_name    arduino_temp_sensor
    command_line    /usr/local/nagios/libexec/essai.c
And in the localhost.cfg I added the following:
        host_name                       localhost
        service_description             Temp
        check_command                   arduino_temp_sensor
I'm confused if the output of the printf should appear in the status information or not. Thanks in advance:D.
Reason: Moved to Nagios Core forum as this is not an idea, rather a question.
abrist
Red Shirt
Re: Nagios status information
Post by abrist »
Does it run from the cli?
I doubt it will run as it is an uncompiled c program (at least that is what *.c usually implies).
y.h
Post by y.h »
Yes it runs normally.
Post by slansing »
Can you show us example output of the plugin? And a copy of it so we can look at it's format? I don't believe what you linked above is the actual plugin correct?
y.h
Post by y.h »
It works when I removed .c.
Great, I am glad your issue has been resolved!
