Need clarification
ravish78
Need clarification
Post by ravish78 »
Can you please confirm if the following are compatible with soalris 10
nagios-plugins-1.4.13
nrpe-2.12
Re: Need clarification
Post by slansing »
There have been guides on how to compile NRPE for Solaris 10, so I would say that yes, it is compatible. Please take a look at this link:
https://www.google.com/search?q=nrpe+so ... =firefox-a
Also, please do not double post, we see everyone's thread so there is no need to bump..
ravish78
Post by ravish78 »
Thank you for the information.
Our system support team was facing issue while installing this below packages and doing make on solaris 10
nrpe-2.12
Attached is the error they are getting during installs.Can you please suggest what might be missing.
Are you using the GNU make or the Solaris make? What is the output of the following command?
make --version
ravish78
Post by ravish78 »
Please find the make version below:
/usr/ccs/bin/make: ELF 32-bit MSB executable SPARC Version 1, dynamically linked, stripped
It seems like you are using the Solaris make. Try using the GNU make instead and see if this is going to fix your issue.
ravish78
Post by ravish78 »
Our support team says they are getting error while installing using gnu make.
PLease find attachment.
Unfortunately, we are not able to test this in house. However, I found a guide on configuring NRPE on Solaris 10, with a possible solution to your problem:
http://utahsysadmin.com/2008/03/14/conf ... olaris-10/
You may try commenting out the following lines in the "nrpe.c" file (699-702):
else if(!strcmp(varvalue,"authpriv"))
		log_facility=LOG_AUTHPRIV;
	else if(!strcmp(varvalue,"ftp"))
		log_facility=LOG_FTP;
or replacing them with:
else if(!strcmp(varvalue,”authpriv”))
			log_facility=LOG_AUTH;
	else if(!strcmp(varvalue,”ftp”))
		log_facility=LOG_DAEMON;
and recompiling. Hope this helps.
You can also try to use our official solaris agent installer, instead of trying to compile it on your own:
http://assets.nagios.com/downloads/nagi ... _Agent.pdf
ravish78
Post by ravish78 »
My support team tried this and still facing issues.
Attached error file .Below are their comments
We have tried by commenting out below lines and then trying to install Nagios but still we are getting error attached in mail:
623 # else if(!strcmp(varvalue,"authpriv"))^M
624 # log_facility=LOG_AUTHPRIV;^M
625 # else if(!strcmp(varvalue,"ftp"))^M
626 # log_facility=LOG_FTP;^M
Also tried to install nagios from http://assets.nagios.com/downloads/nagi ... _Agent.pdf link but same result.
What is the error you received when you followed these instructions?
Because what you posted certainly isn't from following this document...
