We are Planning to make a customized dashboard for our customer ,we want to know what all developers would be required , i have gone thrrough the XI development pdf .
Is there any documents or url where i can find the XI architecture and backend process how it works.
NagiosXi Architecture
Re: NagiosXi Architecture
We do have a guide on entry level backend use:
http://assets.nagios.com/downloads/nagi ... nd_API.pdf
We have talked about getting a document together on the backend API for developers, but I believe it was left at that.
Which is the best way to create a dashboard through xml or php?
Well of course we would recommend using straight php, as that is what just about everything else in XI is generated as, that will also assure others can use the dashboard if you upload it to the exchange.
in a custom dashboard customer wants to have a option on dashboard in which he can access the top warning alerts from a hosgroup
same top critical alerts on the dashboard, but there is no way i can get the above details to display on the dashboard.
is there any possibility ?
Using existing dashlets you could use:
Home > Latest Alerts
Home > Hostgroup Grid
> Hostgroup Overview
> Hostgroup Summary
Etc.. many pages such as these already have dashlets which you can dashify to add to dashboards.
> Hostgroup Overview
> Hostgroup Summary
