Nagios XI running on which port
bojha
Post by bojha »
Hi All,
Could anyone please help me ? to know, on which port number Nagios XI is running/Hosted, and how to check or on which configuration file it is mentioned and the path to that file.
Thanks in advance...
With Regards,
Bijay Ojha
Re: Nagios XI running on which port
Post by slansing »
The interface is loaded via 80/443. Though the checks done by nagios and taken in by nagios travel on different ports "with the exception of NRDS/NRDP."
Could you be more specific on this point?
bojha
Post by bojha »
Hi slansing,
Thank you for your replay,
What i am trying to know is, since every process is running on a particular port, so Nagios XI application is running on which port ? and how can we check that ? and is there any configuration file present in Nagios XI which can describe these details ?
and whenever we are trying to access the nagios Xi application from browser to which port it is connecting ? how can we check that ?
With Regards,
Bijay Ojha
Post by slansing »
As I stated... it is running via 80/443, the XI interface is a served web interface that uses those ports to display information. As I also stated whatever checks you choose to run will likely use different ports, so we would need to know this information to answer that further.
bojha
Post by bojha »
Hi Slansing,
Thank you very much... we got the information...
With Regards,
Bijay
