Service Re-Configuration Failed
amakorju
Post by amakorju »
A failure occurred while attempting to re-configure the service with the new settings
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Warning: Duplicate definition found for timeperiod 'xi_timeperiod_24x7' (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 125)
Error: Could not add object property in file '/usr/local/nagios/etc/timeperiods.cfg' on line 126.
     directives and data defintions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
When Write to Config File: Result
Write host configurations ...
Host configuration files successfully written!
Write service configurations ...
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!
When I Click Verify Configuration: Result
Nagios Core 3.5.0
License: GPL
abrist
Red Shirt
Re: Service Re-Configuration Failed
Post by abrist »
You may have to use the CCM (Core Config Manager) to hunt down the config issue. Go to --> Configure --> Core Config Manager --> Tools --> Write Config Files. Click write and then verify. Post the output here in code wraps.
amakorju
Post by amakorju »
write config file
verify config file
Error: Could not add object property in file '/usr/local/nagios/etc/timeperiods.cfg' on line 132.
Nagios Core 3.5.0
License: GPL
Warning: Duplicate definition found for timeperiod 'xi_timeperiod_24x7' (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 131)
Restart Nagios
RESTART FAILED. CONFIG ERROR:
It seems like the "xi_timeperiod_24x7" is defined twice - once in the database, and once - in the static. I would recommend commenting out (or deleting) the "xi_timeperiod_24x7" definition in "/usr/local/nagios/etc/static/xiobjects.cfg". Save and exit, then run the Write Config Tool again to check for config errors. If there are no errors, Apply Configuration.
Hope this helps.
amakorju
Post by amakorju »
This was the errors (in brief) i got.
Write Config file
Verify Config File
Error: Contact 'xi_default_contact' specified in service 'Ping' for host 'AbiaHouse_Link' is not defined anywhere!
Error: Check period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'AbiaHouse_Link' is not defined anywhere!
Error: Notification period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'AbiaHouse_Link' is not defined anywhere!
Error: Check period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'Abia_House' is not defined anywhere!
Error: Notification period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'Abia_House' is not defined anywhere!
Error: Contact 'xi_default_contact' specified in service 'Ping' for host 'ICT_Operation_Printer' is not defined anywhere!
Error: Check period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'ICT_Operation_Printer' is not defined anywhere!
Error: Notification period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'ICT_Operation_Printer' is not defined anywhere!
Error: Contact 'xi_default_contact' specified in service 'Printer Status' for host 'ICT_Operation_Printer' is not defined anywhere!
Error: Check period 'xi_timeperiod_24x7' specified for service 'Printer Status' on host 'ICT_Operation_Printer' is not defined anywhere!
Error: Notification period 'xi_timeperiod_24x7' specified for service 'Printer Status' on host 'ICT_Operation_Printer' is not defined anywhere!
Error: Check period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'Kaduna_Link' is not defined anywhere!
Error: Notification period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'Kaduna_Link' is not defined anywhere!
Error: Check period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'Lagos_Link' is not defined anywhere!
Error: Notification period 'xi_timeperiod_24x7' specified for service 'Ping' on host 'Lagos_Link' is not defined anywhere!
Error: Check period 'xi_timeperiod_24x7' specified for service 'HTTP' on host 'SigmaFire' is not defined anywhere!
Restart Nagios
sreinhardt
-fno-stack-protector
Post by sreinhardt »
OK, now you are missing the xi_timeperiod_24x7 entirely and the xi_default_contact. What exactly did you change?
amakorju
Post by amakorju »
I deleted the "xi_timeperiod_24x7" definition in "/usr/local/nagios/etc/static/xiobjects.cfg"
danieloo
Post by danieloo »
This happens when you try to edit two things related to each other without applying configuration first...
when this happens within services/hosts i delete those files from disk and re-apply configuration from within nagiosxi, this recreates all config files.
I do not know if this happens for xiobjects.cfg as well, looking at the timestamp it doesn't
danieloo
Post by danieloo »
It clearly says do not modify! please reinstate this file to it's original default maybe using the code below
# XI OBJECTS - DO NOT MODIFY!
# CONTACTS
define contact{
        contact_name                    xi_default_contact
        email                                   root@localhost
        alias                   Default Contact
        host_notification_commands              xi_host_notification_handler
        service_notification_commands   xi_service_notification_handler
        host_notification_period                xi_timeperiod_none
        service_notification_period             xi_timeperiod_none
        host_notification_options               n
        service_notification_options    n
# HOST GROUPS
# TIMEPERIODS
define timeperiod{
        timeperiod_name xi_timeperiod_none
        alias                   None
backup your file: /usr/local/nagios/etc/timeperiods.cfg like
cp /usr/local/nagios/etc/timeperiods.cfg ~/tmp/.
then remove this file
rm /usr/local/nagios/etc/timeperiods.cfg
re-apply config
amakorju
Post by amakorju »
After i try to apply configuration (which won't work), it generates a duplicate nagios.cfg (.swp), timeperiods.cfg (swp) and commands.cfg (swp) in the /usr/local/nagios/etc folder.
