snmp traps
benhank
snmp traps
Post by benhank »
I have a server sending snmp traps to nagios. I am not using NSTI.
When I try to load a mib and check "process traps" I get an error:
Also what is the most up to date documentation for setting up snmp traps?
finally, does NSTI "replace " the wizard? that is are we now urged to use nsti instead of the trap wiz?
Proudly running:
Nagios Network Analyser
Nagios Fusion
abrist
Red Shirt
Re: snmp traps
Post by abrist »
Try:
chown -R root:nagios /usr/share/snmp/mibs
chmod -R g+w /usr/share/snmp/mibs
benhank
Re: snmp traps
Post by benhank »
perfect as usual. thanks all set
Proudly running:
Nagios Fusion
