This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
Frédéric GRANAT
Posts: 445 Joined: Mon Nov 19, 2012 11:36 am
Post
by Frédéric GRANAT » Tue Jul 23, 2013 2:06 am
This morning I've got DB Connect error.
df -k gives :
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mapper/VolGroup00-LogVol00
29329476 27873624 0 100% /
/dev/sda1 101086 31684 64183 34% /boot
tmpfs 1553548 0 1553548 0% /dev/shm
If I run du -ak | sort -nr | head -50 :
18479516 ./var
14924052 ./var/cache
14801588 ./var/cache/logwatch
5775564 ./usr
3447828 ./usr/local
3092276 ./usr/local/nagios
2376680 ./var/log
2265108 ./usr/local/nagios/share
2252168 ./usr/local/nagios/share/perfdata
2172704 ./root
2099204 ./root/dead.letter
1162404 ./var/lib
1156036 ./usr/lib
812372 ./usr/local/nagios/var
786920 ./usr/local/nagios/var/archives
748056 ./usr/share
654724 ./var/cache/logwatch/logwatch.tu6QXprw
651920 ./var/cache/logwatch/logwatch.BLnN6Lwr
651048 ./home
650940 ./home/xadozuk
650904 ./home/xadozuk/client
635460 ./home/xadozuk/client/stage
630272 ./var/cache/logwatch/logwatch.XoN6ZZQM
601328 ./var/lib/pgsql
601280 ./var/lib/pgsql/data
586064 ./home/xadozuk/client/stage/Components
563560 ./var/log/messages.4
563560 ./var/cache/logwatch/logwatch.XoN6ZZQM/messages-archive
563560 ./var/cache/logwatch/logwatch.tu6QXprw/messages-archive
563560 ./var/cache/logwatch/logwatch.BLnN6Lwr/messages-archive
549800 ./var/cache/logwatch/logwatch.MuPbpZfg
480148 ./var/log/mysqld.log.rpmsave
434888 ./var/lib/mysql
402888 ./var/lib/mysql/nagios
379884 ./var/cache/logwatch/logwatch.qThKILD7
365504 ./var/log/mysqld.log
337432 ./var/lib/pgsql/data/base
303584 ./var/cache/logwatch/logwatch.FnGMad8J
302052 ./var/cache/logwatch/logwatch.RROqv8Bi
301764 ./var/cache/logwatch/logwatch.Kc07VSjg
301056 ./var/cache/logwatch/logwatch.yg88Rl1K
300896 ./var/cache/logwatch/logwatch.sgxX1KWo
298740 ./var/cache/logwatch/logwatch.PJ1LcGF9
297152 ./var/cache/logwatch/logwatch.MuPbpZfg/messages
296640 ./var/cache/logwatch/logwatch.RPtIcbU2
295968 ./var/cache/logwatch/logwatch.QCDamggX
292752 ./var/cache/logwatch/logwatch.wueYlovo
292608 ./var/cache/logwatch/logwatch.aNJZF6Uu
289208 ./var/cache/logwatch/logwatch.w776lI6g
Frédéric GRANAT
Post
by Frédéric GRANAT » Tue Jul 23, 2013 9:22 am
Error when trying to connect to Nagiosxi GUI.
[root@nagiosxi ~]# service postgresql start
Starting postgresql service: [FAILED]
Rgds
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Tue Jul 23, 2013 10:29 am
Try clearing some space by removing old log files, tmp files, etc.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
Frédéric GRANAT
Post
by Frédéric GRANAT » Tue Jul 23, 2013 10:34 am
It seems that most of the space is occupied by /var/cache/logwatch
Is there a way to clean that directory.
Otherwise, please indicate which files/directories I could remove.
Frederic
Post
by lmiltchev » Tue Jul 23, 2013 10:51 am
You can try:
Then go to "/etc/logwatch/conf/logwatch.conf" and set "TmpDir" to "/tmp", so that the catch files would be automatically trimmed. If /etc/logwatch/conf/logwatch.conf is blank, you may need to copy the default file from /usr/share/logwatch/default.conf/logwatch.conf to /etc/logwatch/conf/logwatch.conf.
Hope this helps.
Frédéric GRANAT
Post
by Frédéric GRANAT » Wed Jul 24, 2013 1:58 am
=> What do you mean
Apart from that : I cleaned logwatch and now nagiosxi is reachable.
abrist
Red Shirt
Posts: 8334 Joined: Thu Nov 15, 2012 1:20 pm
Post
by abrist » Wed Jul 24, 2013 9:37 am
Frédéric GRANAT wrote: so that the catch files would be automatically trimmed
=> What do you mean
Files in /tmp are routinely trimmed (removed), especially if the root file system is running low on space.
Come to the
Dark Side .
