Nagios XI NRPE issue
Nagios XI server:
CentOS 6.4
64 bit
install VMWare image
Monitoring environment
Centos 6.4
64 bit
installed agent via instructions using /fullinstall
no special configurations
I'm having issues of monitoring the Linux server,
I have attached the one with SSL and one w/o SSL
in my client server, i'm getting messages in /var/log/messages
Jul 24 15:39:12 cvg-nagois-test xinetd[24807]: FAIL: nrpe address from=::ffff:10.1.100.21
Jul 24 15:39:12 cvg-nagois-test xinetd[9511]: EXIT: nrpe status=0 pid=24807 duration=0(sec)
Jul 24 15:39:19 cvg-nagois-test xinetd[9511]: START: nrpe pid=24808 from=::ffff:10.1.100.21
Jul 24 15:39:19 cvg-nagois-test xinetd[24808]: FAIL: nrpe address from=::ffff:10.1.100.21
Jul 24 15:39:19 cvg-nagois-test xinetd[9511]: EXIT: nrpe status=0 pid=24808 duration=0(sec)
my configuration file is already configured with allowed_hosts including the nagiosXi IP
one item to note is I can't locate the nrpe binary, not sure if that is a factor about this issue.
thanks
CentOS 6.4
64 bit
Centos 6.4
64 bit
thanks
Re: Nagios XI NRPE issue
Run the following commands on the client machine and show the output:
netstat -at | grep nrpe
grep dont_blame_nrpe /usr/local/nagios/etc/nrpe.cfg
grep only_from /etc/xinetd.d/nrpe
service xinetd statusBe sure to check out our Knowledgebase for helpful articles and solutions!
For the system showing the incomplete SSL handshake error, were you sure to compile NRPE with SSL support? Both of these issues are discussed in this document:
http://assets.nagios.com/downloads/nagi ... utions.pdf
output belowlmiltchev wrote:Run the following commands on the client machine and show the output:
netstat -at | grep nrpe grep dont_blame_nrpe /usr/local/nagios/etc/nrpe.cfg grep only_from /etc/xinetd.d/nrpe service xinetd status
tcp 0 0 *:nrpe *:* LISTEN
dont_blame_nrpe=1
# command arguments *AND* the dont_blame_nrpe directive in this
only_from = 10.2.0.162 127.0.0.1
xinetd (pid 9511) is running...
some more info, I checked the port and it's open
from Nagios XI Server to Remote Server
[root@cvglobal ~]# nmap 10.1.100.20 -p 5666
Starting Nmap 5.51 ( http://nmap.org ) at 2013-07-24 17:29 EDT
Nmap scan report for cvg-nagois-test.cvglobal.com (10.1.100.20)
Host is up (0.00027s latency).
PORT STATE SERVICE
5666/tcp open nrpe
MAC Address: 00:50:56:8A:63:45 (VMware)
Nmap done: 1 IP address (1 host up) scanned in 0.13 seconds
[root@cvglobal ~]# /usr/local/nagios/libexec/check_nrpe -H 10.1.100.20
CHECK_NRPE: Error - Could not complete SSL handshake.
is there the need to manually include enable-ssl in the install, the whole install process is scripted up,
I did try to check localhost
[root@cvglobal ~]# /usr/local/nagios/libexec/check_nrpe -H localhost
NRPE v2.12
not sure if this will make a difference or not
PORT STATE SERVICE
5666/tcp open nrpe
NRPE v2.12
Open the /etc/xinet.d/nrpe on the client in a text editor:
and add your Nagios XI server's IP:
See if this is going to solve your issue.
vi /etc/xinet.d/nrpeRestart the daemon:only_from = 10.2.0.162 127.0.0.1 10.1.100.21
service xinetd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
the error message changed, I put a screenshot of the nagiosXI interface
here's the message I'm receiving on the client system logs
Jul 24 16:46:26 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27569 duration=0(sec)
Jul 24 16:46:31 cvg-nagois-test xinetd[27241]: START: nrpe pid=27581 from=::ffff:10.1.100.21
Jul 24 16:46:31 cvg-nagois-test xinetd[27241]: START: nrpe pid=27582 from=::ffff:10.1.100.21
Jul 24 16:46:31 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27582 duration=0(sec)
Jul 24 16:46:31 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27581 duration=0(sec)
Jul 24 16:46:36 cvg-nagois-test xinetd[27241]: START: nrpe pid=27605 from=::ffff:10.1.100.21
Jul 24 16:46:36 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27605 duration=0(sec)
Jul 24 16:46:37 cvg-nagois-test xinetd[27241]: START: nrpe pid=27637 from=::ffff:10.1.100.21
Jul 24 16:46:37 cvg-nagois-test nrpe[27637]: Error: Could not complete SSL handshake. 1
Jul 24 16:46:37 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27637 duration=0(sec)
Jul 24 16:46:38 cvg-nagois-test xinetd[27241]: START: nrpe pid=27638 from=::ffff:10.1.100.21
Jul 24 16:46:38 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27638 duration=0(sec)
Jul 24 16:46:45 cvg-nagois-test xinetd[27241]: START: nrpe pid=27641 from=::ffff:10.1.100.21
Jul 24 16:46:45 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27641 duration=0(sec)
Jul 24 16:46:52 cvg-nagois-test xinetd[27241]: START: nrpe pid=27644 from=::ffff:10.1.100.21
Jul 24 16:46:57 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27644 duration=5(sec)
Jul 24 16:46:58 cvg-nagois-test xinetd[27241]: START: nrpe pid=27666 from=::ffff:10.1.100.21
Jul 24 16:46:58 cvg-nagois-test xinetd[27241]: START: nrpe pid=27667 from=::ffff:10.1.100.21
Jul 24 16:46:58 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27666 duration=0(sec)
Jul 24 16:46:58 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27667 duration=0(sec)
Jul 24 16:47:12 cvg-nagois-test xinetd[27241]: START: nrpe pid=27680 from=::ffff:10.1.100.21
Jul 24 16:47:12 cvg-nagois-test xinetd[27241]: EXIT: nrpe status=0 pid=27680 duration=0(sec)
Can you run one of the failing check from the command line and show the output? For example, it could be something like this:
cd /usr/local/nagios/libexec
./check_nrpe -H <client_IP> -t 30 -c check_disk -a '-w 20% -c 10% -p /'Be sure to check out our Knowledgebase for helpful articles and solutions!
[root@cvglobal ~]# /usr/local/nagios/libexec/check_nrpe -H 10.1.100.20 -t 30 -c check_disk -a '-w 20% -c 10% -p /'lmiltchev wrote:Can you run one of the failing check from the command line and show the output? For example, it could be something like this:
cd /usr/local/nagios/libexec ./check_nrpe -H <client_IP> -t 30 -c check_disk -a '-w 20% -c 10% -p /'
DISK OK - free space: / 424322 MB (98% inode=99%);| /=6200MB;362845;408201;0;453557
I also tried
NRPE v2.14
I have updates, this morning I went on and deleted my host and reconfigured it, it seems to be working now...
this was happening to me for Windows machine, will try to configure it again
