SNMP configuration on cisco ASA 5500 series
prashanthm88
Post by prashanthm88 »
We are trying to configure SNMP on one of our Cisco ASA 5505 appliance. We configured the ASA and NagiosXI both for SNMP.
When we run the setup on nagios, notthing is working except ping.
192.168.20.1 Cisco VPN Sessions Unknown 1h 29m 49s 5/5 2013-07-24 21:42:58 Usage:check_snmp -H <ip_address> -o <OID> [-w warn_range] [-c crit_range]
IBM RSA II Adapter Temperature Unknown 1h 28m 58s 5/5 2013-07-24 21:38:49 Usage:check_snmp -H <ip_address> -o <OID> [-w warn_range] [-c crit_range]
ifDescr.10 Unknown 55m 2s 5/5 2013-07-24 21:42:46 SNMP problem - No data received from host
ifDescr.14 Unknown 54m 12s 5/5 2013-07-24 21:43:39 SNMP problem - No data received from host
ifDescr.15 Unknown 53m 14s 5/5 2013-07-24 21:39:33 SNMP problem - No data received from host
I also attached a file which has the error file.
I'm very new Nagios.
abrist
Red Shirt
Re: SNMP configuration on cisco ASA 5500 series
Post by abrist »
It looks like you are running an snmpget, not a trap. Have you tried walking the device to make sure snmp is enabled and your community string works?
snmpwalk -v1 -c <community> <ip of device>
snmpwalk -v2c -c <community> <ip of device>
prashanthm88
Thanks for the reply.
When I run SNMPwalk wizard, I cleared the data in ODI field and presses next button. which actually found all the information of our network appliace. But, when I hit next it showing me an error.
"SNMP problme- No data received from the HOST"
Do I have to provide any information in SNMP serveries, I left those fields blank
With the SNMP Walk wizard you can run into problems if you clear the starting OID because of default limit in php.
If you add the following to your /etc/php.ini and restart apache you should be able to re-run the wizard and likely get correct results
add to /etc/php.ini
max_input_vars = 100000
then
service httpd restart
prashanthm88
Thanks for you're quick responce.
I did added max_input_vars = 100000 line to /etc/php.ini, but i'm getting the same error."SNMP problme- No data received from the HOST".
When I clear the filed in ODI I can see everything like host name , no of ports, services running.. But when I hit finish button, it shows an error like this
prashanthm88
Even if I don't clear the filed, it actually shows all the sevices and asking me to select the ODI's. I've checked all the ODI check boxes. In the next screen it shows like in the screenshot down below.
Please tell me if I'm missing any steps.
By any chance did you change the default check_snmp command in the CCM?
Can you go to one of these services in the CCM and run the "Test Command" link and show the output
prashanthm88
I ran this command inside /usr/local/nagios/libexec
./check_snmp -H 192.168.20.1 -o "1.3.6.1.4.1.9.1.745" -C Testcom -U testuser -A testpassword -x AES -X testpassword -L authPriv -P 3 -a MD5 -u W -w 1000 -c 1050
The output which I got "SNMP problem - No data received from host"
I logged in to nagios web portal, ran the same command inside CCM. Go the same error as output.
Please look at the screenshots.
prashanthm88
I ran the snmp wizard with SNMP V1, it did work. But when I ran with theSNMP V3 I'm getting an error "SNMP problem - No data received from host"
I'm I missing some thing here, BTW I gave the same credentials to Solarwinds. it worked perfectly fine with out any errors.
It just hit me that you may need to upgrade your Nagios plugins so you can set
 -x, --privproto=[DES|AES]
Which wasn't present a few versions ago..
You can download the package here
http://sourceforge.net/projects/nagiosp ... ug/1.4.16/
Then on the XI server
tar -xzf nagios-plugins-1.4.16.tar.gz
cd nagios-plugins-1.4.16
./configure
make clean
make
make install
