Is there a version for windows 7? I am installing the 1.9.2 version but still get the:
Microsoft visual C++ Runtime Library error
I clicked on the link and downloaded/installed:
Microsoft Visual C++ 2005 Redistributable Package (x86)
Still getting the C ++ error. Please advise
NagEventLog 1.9.2 errors on windows 7
Re: NagEventLog 1.9.2 errors on windows 7
emolina,
NagEventLog has not been updated for sometime. However, you should be able to hit "OK" past the error messages and it will install.
-Yancy
-Yancy
Thanks Yancy,
I have installed it but the default port is 5667 for the NSCA daemon, and also on the Nagios XI inbound but I only see port 5666 on the windows client and I don't see ports 5666 or 5667 on the Nagios XI side. Any suggestions?
emolina,
Have you followed the instructions for configuring NSCA in Nagiosxi
http://assets.nagios.com/downloads/nagi ... ith_XI.pdf
Particularly step 3 is important.
-Yancy
-Yancy
Hi Yancy, Thanks for your responses and help. The issue has been resolved not sure if you need to close this issue out. Thanks again.
