There seems to be a change which was made that prevent nagios from taking the new configuration files.
the configuration error is:
Processing object config file '/usr/local/nagios/etc/services/itesx03.nimblestorage.com.cfg'...
Processing object config file '/usr/local/nagios/etc/services/win7-corp2.nimblestorage.com.cfg'...
Processing object config file '/usr/local/nagios/etc/services/gmini.nimblestorage.com.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/rdp.nimblestorage.com.cfg'...
Error: Could not expand dependent services specified in service dependency (config file '/usr/local/nagios/etc/servicedependencies.cfg', starting on line 14)
So looking at the /usr/local/nagios/etc/servicedependencies.cfg file, i don't see anything there. I've tried deleting the white space but that does not seem to fix the issue:
# Service dependency configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2013-06-28 22:16:22
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
# END OF FILE
please advise.
cannot modify Nagios configuration
Re: cannot modify Nagios configuration
Go to: CCM->Advanced->Service Dependencies, click on the "View Text Config" actions button and post the config (hide the sensitive info).
# Date: 2013-07-29 13:14:36
define servicedependency {
hostgroup_name Linux-based network storage
service_description NFS health status
inherits_parent 1
execution_failure_criteria c,
notification_failure_criteria c,
dependency_period 24x7
# END OF FILE
inherits_parent 1
# END OF FILE
I believe you are missing two directives in the config:
You should have:
dependent_hostgroup_name
dependent_service_descriptionUnder "Service Dependency Management" click on "Manage Dependent Hostgroups" and "Manage Service Dependencies" and make some mods. After that, run the Write Config Tool to check for config errors. If there are no errors, apply configuration.define servicedependency {
dependent_hostgroup_name <some_hostgroup>
dependent_service_description <some_service>
inherits_parent 1
My apologies, but i do not see "Service Dependency Management" anywhere on the interface. I've searched everywhere.
this can be marked resolved. i removed the service dependency.
thanks for your help.
bmusson,
Thanks for letting us know!
-Yancy
-Yancy
