Graph Lag?
Pilly170
Graph Lag?
Post by Pilly170 »
On all my graphs it seems that nagios is lagging. For example the time is now 17:00
But its only showing up until 16:15... the updates on this is to poll every 5 mins. its happening to all my graphs on my dashboard. The VM nagios is running on seems fine. No issues with the monitoring engine.
Any ideas?
sreinhardt
-fno-stack-protector
Re: Graph Lag?
Post by sreinhardt »
Is your nagios server setup on ntp? Are the scheduled checks that are being scheduled now, also at this lagged time? Can you run the commands below please.
cat /etc/localtime
grep -i 'date.timezone' /etc/php.ini
Pilly170
Re: Graph Lag?
Post by Pilly170 »
Thing is its ok now, but towards the end of day this happens. For instance at this moment it looks ok, just gets further and further behind.
LMTBSTGMTBDST
GMT0BST,M3.5.0/1,M10.5.0
[root@nagios ~]# grep -i 'date.timezone' /etc/php.ini
; http://www.php.net/manual/en/datetime.c ... e.timezone
date.timezone = Europe/London
Re: Graph Lag?
2 possible things:
1. there will be a lag if you have setup RRDCACHED
2. If not we should check the following when you are experiencing this
ll /usr/local/nagios/var/spool/xidpe | wc -l
ll /usr/local/nagios/var/spool/perfdata | wc -l
tail /usr/local/nagios/var/npcd.log
tail /usr/local/nagios/var/perfdata.log
Pilly170
Re: Graph Lag?
Post by Pilly170 »
I've never knowingly enable it so I did what you said. The logs were massive so I zipped them up.
[root@nagios ~]# ll /usr/local/nagios/var/spool/xidpe | wc -l
3
[root@nagios ~]# ll /usr/local/nagios/var/spool/perfdata | wc -l
8
https://dl.dropboxusercontent.com/u/519 ... s-Logs.zip
Re: Graph Lag?
Looks like you are hitting a default load limit.
If you have a fairly powerful machine you can increase it from the defaults
edit
change
load_threshold = 10.0
to a higher value, 10*# of CPU's
Then
service npcd restart
Pilly170
Re: Graph Lag?
Post by Pilly170 »
edit what file?
abrist
Red Shirt
Re: Graph Lag?
Post by abrist »
vi /usr/local/nagios/etc/pnp/npcd.cfg
Change:
To:
load_threshold = 20.0
Restart npcd:
Pilly170
Re: Graph Lag?
Post by Pilly170 »
Thanks I've changed it and will monitor.
abrist
Red Shirt
Re: Graph Lag?
Post by abrist »
No problem.
