UNKNOWN: No handler for that command” error with check_ad
imran_khan
Post by imran_khan »
I am getting “UNKNOWN: No handler for that command” error in Nagios system. All the service is working fine expect check_ad.
Locally I am getting response. Please find the details for the same.
Nsc.ini file setting:-
[NRPE Client Handlers]
command[checkDC]=C:\Nagios++\scripts\check_ad.exe -d -v
Command setting in Nagios system:-
command_name checkDC
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p $ARG1$ -c checkDC -a ShowAll
Command response from local windows server:-
C:\Nagios++\scripts>check_ad.exe -d -v
AD CRITICAL: Services OK, Replications CRITICAL, Advertising OK, FSMO Check OK,
RID Manager OK, Machine Account OK, KCC Event OK, FRS Event OK, FRS Sysvol OK
Imran Khan.
yancy
Re: UNKNOWN: No handler for that command” error with check_a
Post by yancy »
imran_khan,
What modules have you enabled in the NSC.ini file.
Check the following...
[modules]
NRPEListener.dll
NSClientListener.dll
CheckExternalScripts.dll
-Yancy
imran_khan
Please find the modules details.
[modules]
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
NRPEListener.dll
CheckEventLog.dll
CheckHelpers.dll
CheckWMI.dll
Imran Khan.
this looks incorrect
remove
place check_ad.exe in C:\Program Files\NSClient++\scripts
Then add the following to [External Scripts] section
[External Scripts]
checkDC=scripts\check_ad.exe -d -v
restart NSClient++
imran_khan
Thanks. I have made the changes as per your instruction. I am getting error “FSMO Check No result” when ran this command locally. Also getting the same error in Nagios system as well. Service FSMO is working fine, so why I am getting this error. Please suggest me.
AD CRITICAL: Services OK, Replications OK, Advertising OK, FSMO Check No result,
Status Information: AD CRITICAL: Services OK, Replications OK, Advertising OK, FSMO Check No result, RID Manager OK, Machine Account OK, KCC Event OK, FRS Event OK, FRS Sysvol OK
Imran Khan.
yancy
Post by yancy »
imran_khan,
can you run dcdiag from the command line and post the results.
dcdiag
-Yancy
imran_khan
It is not showing any fail services. Please find the output of dcdiag command.
Please check and remove it from the post thread.
Directory Server Diagnosis
Performing initial setup:
   Trying to find home server...
   * Verifying that the local machine xyz, is a Directory Server.
   Home Server = xyz
   * Connecting to directory service on server xyz.
   * Identified AD Forest.
   Collecting AD specific global data
   * Collecting site info.
   Calling ldap_search_init_page(hld,CN=Sites,CN=Configuration,DC=example,DC=net,LDAP_SCOPE_SUBTREE,(objectCategory=ntDSSiteSettings),.......
   The previous call succeeded
   Iterating through the sites
   Looking at base site object: CN=NTDS Site Settings,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=example,DC=net
   Getting ISTG and options for the site
   * Identifying all servers.
   Calling ldap_search_init_page(hld,CN=Sites,CN=Configuration,DC=example,DC=net,LDAP_SCOPE_SUBTREE,(objectClass=ntDSDsa),.......
   The previous call succeeded....
   Iterating through the list of servers
   Getting information for the server CN=NTDS Settings,CN=xyz,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=example,DC=net
   objectGuid obtained
   InvocationID obtained
   dnsHostname obtained
   site info obtained
   All the info for the server collected
   * Identifying all NC cross-refs.
   * Found 1 DC(s). Testing 1 of them.
   Done gathering initial info.
Doing initial required tests
   Testing server: Default-First-Site-Name\xyz
      Starting test: Connectivity
         * Active Directory LDAP Services Check
         Determining IP4 connectivity
         * Active Directory RPC Services Check
         ......................... xyz passed test Connectivity
Doing primary tests
      Starting test: Advertising
         The DC xyz is advertising itself as a DC and having a DS.
         The DC xyz is advertising as an LDAP server
         The DC xyz is advertising as having a writeable directory
         The DC xyz is advertising as a Key Distribution Center
         The DC xyz is advertising as a time server
         The DS xyz is advertising as a GC.
         ......................... xyz passed test Advertising
      Test omitted by user request: CheckSecurityError
      Test omitted by user request: CutoffServers
      Starting test: FrsEvent
         * The File Replication Service Event log test
         Skip the test because the server is running DFSR.
         ......................... xyz passed test FrsEvent
      Starting test: DFSREvent
         The DFS Replication Event Log.
         ......................... xyz passed test DFSREvent
      Starting test: SysVolCheck
         * The File Replication Service SYSVOL ready test
         File Replication Service's SYSVOL is ready
         ......................... xyz passed test SysVolCheck
      Starting test: KccEvent
         * The KCC Event log test
         Found no KCC errors in "Directory Service" Event log in the last 15 minutes.
         ......................... xyz passed test KccEvent
      Starting test: KnowsOfRoleHolders
         Role Schema Owner = CN=NTDS Settings,CN=xyz,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=example,DC=net
         Role Domain Owner = CN=NTDS Settings,CN=xyz,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=example,DC=net
         Role PDC Owner = CN=NTDS Settings,CN=xyz,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=example,DC=net
         Role Rid Owner = CN=NTDS Settings,CN=xyz,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=example,DC=net
         Role Infrastructure Update Owner = CN=NTDS Settings,CN=xyz,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=example,DC=net
         ......................... xyz passed test KnowsOfRoleHolders
      Starting test: MachineAccount
         Checking machine account for DC xyz on DC xyz.
         * SPN found :LDAP/xyz.example.net/example.net
         * SPN found :LDAP/xyz.example.net/pqr
         * SPN found :LDAP/8198b45d-94f2-4fd9-915f-25c4489eb0c3._msdcs.example.net
         * SPN found :E3514235-4B06-11D1-AB04-00C04FC2DCD2/8198b45d-94f2-4fd9-915f-25c4489eb0c3/example.net
         * SPN found :HOST/xyz.example.net/example.net
         * SPN found :HOST/xyz.example.net/pqr
         * SPN found :GC/xyz.example.net/example.net
         ......................... xyz passed test MachineAccount
      Starting test: NCSecDesc
         * Security Permissions check for all NC's on DC xyz.
         * Security Permissions Check for
           DC=ForestDnsZones,DC=example,DC=net
            (NDNC,Version 3)
           DC=DomainDnsZones,DC=example,DC=net
            (NDNC,Version 3)
           CN=Schema,CN=Configuration,DC=example,DC=net
            (Schema,Version 3)
            (Configuration,Version 3)
           DC=example,DC=net
            (Domain,Version 3)
         ......................... xyz passed test NCSecDesc
      Starting test: NetLogons
         * Network Logons Privileges Check
         Verified share \\xyz\netlogon
         Verified share \\xyz\sysvol
         ......................... xyz passed test NetLogons
      Starting test: ObjectsReplicated
         xyz is in domain DC=example,DC=net
         Checking for CN=xyz,OU=Domain Controllers,DC=example,DC=net in domain DC=example,DC=net on 1 servers
            Object is up-to-date on all servers.
         Checking for CN=NTDS Settings,CN=xyz,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=example,DC=net in domain CN=Configuration,DC=example,DC=net on 1 servers
         ......................... xyz passed test ObjectsReplicated
      Test omitted by user request: OutboundSecureChannels
      Starting test: Replications
         * Replications Check
         * Replication Latency Check
         ......................... xyz passed test Replications
      Starting test: RidManager
         * Available RID Pool for the Domain is 1601 to 1073741823
         * xyz.example.net is the RID Master
         * DsBind with RID Master was successful
         * rIDAllocationPool is 1101 to 1600
         * rIDPreviousAllocationPool is 1101 to 1600
         * rIDNextRID: 1108
         ......................... xyz passed test RidManager
      Starting test: Services
         * Checking Service: EventSystem
         * Checking Service: RpcSs
         * Checking Service: NTDS
         * Checking Service: DnsCache
         * Checking Service: DFSR
         * Checking Service: IsmServ
         * Checking Service: kdc
         * Checking Service: SamSs
         * Checking Service: LanmanServer
         * Checking Service: LanmanWorkstation
         * Checking Service: w32time
         * Checking Service: NETLOGON
         ......................... xyz passed test Services
      Starting test: SystemLog
         * The System Event log test
         Found no errors in "System" Event log in the last 60 minutes.
         ......................... xyz passed test SystemLog
      Test omitted by user request: Topology
      Test omitted by user request: VerifyEnterpriseReferences
      Starting test: VerifyReferences
         The system object reference (serverReference)
         CN=xyz,OU=Domain Controllers,DC=example,DC=net and
         backlink on
         are correct.
         The system object reference (serverReferenceBL)
         CN=xyz,CN=Topology,CN=Domain System Volume,CN=DFSR-GlobalSettings,CN=System,DC=example,DC=net
         and backlink on
         are correct.
         The system object reference (msDFSR-ComputerReferenceBL)
         and backlink on
         CN=xyz,OU=Domain Controllers,DC=example,DC=net are
         correct.
         ......................... xyz passed test VerifyReferences
      Test omitted by user request: VerifyReplicas
      Test omitted by user request: DNS
   Running partition tests on : ForestDnsZones
      Starting test: CheckSDRefDom
         ......................... ForestDnsZones passed test CheckSDRefDom
      Starting test: CrossRefValidation
         CrossRefValidation
   Running partition tests on : DomainDnsZones
         ......................... DomainDnsZones passed test CheckSDRefDom
         CrossRefValidation
   Running partition tests on : Schema
         ......................... Schema passed test CheckSDRefDom
         ......................... Schema passed test CrossRefValidation
   Running partition tests on : Configuration
         ......................... Configuration passed test CheckSDRefDom
         ......................... Configuration passed test CrossRefValidation
   Running partition tests on : example
         ......................... example passed test
         CheckSDRefDom
         CrossRefValidation
   Running enterprise tests on : example.net
      Starting test: LocatorCheck
         GC Name: \\xyz.example.net
         Locator Flags: 0xe00071fd
         PDC Name: \\xyz.example.net
         Time Server Name: \\xyz.example.net
         Preferred Time Server Name: \\xyz.example.net
         KDC Name: \\xyz.example.net
         ......................... example.net passed test
         LocatorCheck
      Starting test: Intersite
         Skipping site Default-First-Site-Name, this site is outside the scope
         provided by the command line arguments provided.
         Intersite
yancy
Post by yancy »
imran_khan,
I don't see anything that says FsmoCheck is OK...
for example,
Running enterprise tests on : neptune.net
      ......................... neptune.net passed test Intersite
   Starting test: FsmoCheck
      ......................... neptune.net passed test FsmoCheck
Any idea why FsmoCheck isn't showing in dcdiag?
-Yancy
imran_khan
Below FSMO roles are showing OK in dcdiag result. It will not show FSMO as a service in dcdiag result.
PDC
Rid
Infrastructure
Schema
Domain
Imran khan.
imran_khan
Any solution or advice?
Imran Khan.
