Notification Command Failing
agutierrezps
Post by agutierrezps »
Hello everyone,
I'm having a problem when it comes to the notification commands. You see i have a script made in perl which sends tweets as alarms, if i execute it manually it works but it doesnt works when an alarm is activacted and sends the notification.
Here is my command definition:
        command_name    host-notify-by-twitter_mex
        command_line      /usr/local/nagios/bin/twitter.pl MEX $HOSTNAME$ "State: $HOSTSTATE$" "Info: $HOSTOUTPUT$" "Date: $LONGDATETIME$" >> /FILES/latam/nagios/var/debug_twitter.log
        command_name    notify-by-twitter_mex
        command_line     /usr/loca/nagios/bin/twitter.pl MEX '$HOSTSTATE$' '$HOSTNAME$' '$SERVICEDESC$' '$SERVICEOUTPUT$' > /FILES/latam/nagios/var/debug_twitter.log
This is driving me nuts, since the script is working but no there is no reason given why the notification executes the command but nothing happens.
Re: Notification Command Failing
Have you added the notification command to a contact?
What are the permissions on these files?
ls -l /usr/local/nagios/bin/twitter.pl
ls -l /FILES/latam/nagios/var/debug_twitter.log
The log needs to be writable by the nagios user and twitter.pl needs to be executable
Doe twitter.pl have any use lib lines in the script?
agutierrezps
Thanks for you answer.
Yes i have added the notification command to a contact.
The permissions of the files are the following
-rwxr-xr-x 1 twitter.pl
-rw-rw-r-- 1 debug_twitter.log
This is the content of the script in perl
use Net::Twitter::Lite::WithAPIv1_1;
use Switch;
my $consumer_key = "";
my $consumer_secret = "";
my $access_token = "";
my $access_token_secret = "";
my $region = $ARGV[0];
my $type = $ARGV[1];
my $hostname = $ARGV[2];
my $service_desc = $ARGV[3];
my $service_out = $ARGV[4];
my $url = $url = "http://localhost.nagios.com/nagios/cgi-bin/extinfo.cgi?type=2&host=";
my $tweet = Net::Twitter::Lite::WithAPIv1_1->new(consumer_key => $consumer_key,
                                            consumer_secret => $consumer_secret,
                                            access_token => $access_token,
                                            access_token_secret => $access_token_secret);
my $prepare_tweet = $type." in ".$hostname." on ".$service_desc." ( ".$service_out." ) ".$url.$hostname."&service=".$service_desc;
my $result = $tweet->update({status => $prepare_tweet});
I've deleted the tokens for twitter
This use lib you mention i don't have it.
My perl instalation has the following folders
bin, lib, man
Greetings.
abrist
Red Shirt
Post by abrist »
You will need to install a package for that lib if you do not have it. What distro are you running?
agutierrezps
I already have the lib's needed for Twitter.
My question was about the "use lib".
scottwilkerson said this
Greetings.
abrist
Red Shirt
Post by abrist »
I believe Scott was referring to the lines:
use Switch;
Those libraries are installed, correct?
agutierrezps
Yes, that is correct.
Those libraries are installed.
Greetings
abrist
Red Shirt
Post by abrist »
What does a standard output of the script form the cli look like?
Though probably not related, your commands above are odd:
The order of passed macros are different between the two commands - one starts with HOSTSTATE, the other starts with HOSTNAME. Additionally, The first command appends to the log (>>), while the other overwrites the log (>). Finally, the second command has an invalid path:
/usr/loca/nagios......
should be:
/usr/local/nagios.......
