Unable to retrieve Printer Event log alerts
gm_rajkumar
Post by gm_rajkumar »
I wanted to see the printer - TOSHIBA e-studio 5540c alerts in Nagios, enclosed the screenshot for your reference. I have tried with http://exchange.nagios.org/directory/Pl ... ck/details -SNMP PRINTER. However im unable to get the event messages of the printer.
./check_snmp_printer -H 192.168.10.10 -C public -x MESSAGES
UNKNOWN: Can't determine messages. Device does not support this OID.
Kindly help me out this issue.. thanks in advance!!
Regards,
Raj.
yancy
Re: Unable to retrieve Printer Event log alerts
Post by yancy »
gm_rajkumar,
What version of SNMP haave you configured?
http://business.toshiba.com/downloads/K ... on-v04.pdf
Page 53 describes how to configure SNMP on your device.
-Yancy
gm_rajkumar
Im using version 1 and let me know how to get the alert message to be viewed from nagios??
Regards,
Raj.
From nagios can you access the device via SNMP from the command line?
snmpget -v 1 -c public 192.168.10.10 sysDescr.0
siriideepak
Unable to get log alerts of printer in Nagios
Post by siriideepak »
Regards,
Deepak.P
abrist
Red Shirt
Re: Unable to get log alerts of printer in Nagios
Post by abrist »
Does this printer support snmp? If so, what mibs/oids does it use?
gm_rajkumar
The result i got is as shown below
snmpget -v 1 -c public 192.168.0.1 sysDescr.0
SNMPv2-MIB::sysDescr.0 = STRING: TOSHIBA e-STUDIO5540C
Regards,
Raj
gm_rajkumar
This printer supports snmp. I can able to get all the data except ./check_snmp_printer -H 192.168.10.10 -C public -x MESSAGES. It uses 1.3.6.1.2.1.43.18.1.1.8 as OID for MESSAGES.
Regards,
Deepak.P
OK, good now lets try the OID that the plugin uses for MESSAGES
snmpwalk -v 1 -c public 192.168.0.1 1.3.6.1.2.1.43.18.1.1.8
I merged these 2 topic because they are exactly the same posts with different names
