Question Reference Backend APIs
mrochelle
Post by mrochelle »
Is it possible to add command arguments in the return data from Hosts and Services backend URL data pulls? If yes, what would I need to do to add this enhancement?
yancy
Re: Question Reference Backend APIs
Post by yancy »
mrochelle,
The backend API does include check command arguments. In this case the check command argument is check_total_procs.
<check_command>check_nrpe!check_total_procs!</check_command>
Is that what you were looking for?
-Yancy
mrochelle
Post by mrochelle »
Let me clarify, when I issue the backend URLs http://HOSTIP/nagiosxi/backend/?cmd=get ... name...etc, the returned data dose not include command args with threshold data. I have the same request with getservices URL also. I'm guessing I may be able to modify the script to add these fields?
It doesn't with the cmd=gethosts
but it does with cmd=gethoststatus
ie
http://hostip/nagiosxi/backend/?cmd=gethoststatus&username=XXXX&ticket=XXXX
mrochelle
Post by mrochelle »
Case closed! Thank You!!! That certainly has all the information needed. :oops:
