DB error
DB error
We are getting thousands of these errors in our messages log - 800MB since last night. I searched the forums found where it was recommended to run the 'repairmysql' script. Still getting the same errors. Not disk space issues though I have to keep clearing the messages log to make sure that we don't run into one.
Not sure what to do at this point.....
Aug 2 11:47:18 lpnagv01 ndo2db: mysql_error: 'Duplicate entry '2147483647' for key 1'
Aug 2 11:47:18 lpnagv01 ndo2db: Error: mysql_query() failed for 'INSERT INTO nagios_timedeventqueue SET instance_id='1', event_type='0', queued_time=FROM_UNIXTIME(1375458363), queued_time_usec='400903', scheduled_time=FROM_UNIXTIME(1375458615), recurring_event='0', object_id='917''
http://support.nagios.com/forum/viewtop ... IME#p36753
-rw------- 1 root root 816963234 Aug 2 11:59 messages
/dev/mapper/VolGroup00-LogVol00
8.6G 6.0G 2.3G 73% /
/dev/sda1 99M 18M 76M 20% /boot
tmpfs 1.5G 0 1.5G 0% /dev/shm
/dev/mapper/VolGroup00-LV02
9.9G 7.4G 2.1G 79% /usr/local
/dev/mapper/VolGroup00-LV03
9.9G 7.7G 1.7G 82% /store
tmpfs 50M 19M 32M 38% /usr/local/ramdisk
Re: DB error
This can happen if the auto_increment for timedeventqueue_id in nagios_timedeventqueue has hit the limit for int
Run the following to resolve this issue
echo "ALTER TABLE nagios_timedeventqueue MODIFY timedeventqueue_id SERIAL;"|mysql -pnagiosxi nagiosRe: DB error
I did that, got same result. Reran repairmysql, still same result. Interesting that the error is always the same number - 2,324,513 since last night around 4pm EDT.
Aug 1 17:14:24 lpnagv01 ndo2db: mysql_error: 'Duplicate entry '2147483647' for key 1'
Re: DB error
Does this look right to you? `timedeventqueue_id` bigint(20) unsigned NOT NULL auto_increment
[root@lpnagv01 log]# echo "ALTER TABLE nagios_timedeventqueue MODIFY timedeventqueue_id SERIAL;"|mysql -pnagiosxi nagios
[root@lpnagv01 log]# echo "SHOW CREATE TABLE nagios_timedeventqueue;"|mysql -pnagiosxi nagios
Table Create Table
nagios_timedeventqueue CREATE TABLE `nagios_timedeventqueue` (\n `timedeventqueue_id` bigint(20) unsigned NOT NULL auto_increment,\n `instance_id` smallint(6) NOT NULL default '0',\n `event_type` smallint(6) NOT NULL default '0',\n `queued_time` datetime NOT NULL default '0000-00-00 00:00:00',\n `queued_time_usec` int(11) NOT NULL default '0',\n `scheduled_time` datetime NOT NULL default '0000-00-00 00:00:00',\n `recurring_event` smallint(6) NOT NULL default '0',\n `object_id` int(11) NOT NULL default '0',\n PRIMARY KEY (`timedeventqueue_id`),\n UNIQUE KEY `timedeventqueue_id` (`timedeventqueue_id`),\n UNIQUE KEY `timedeventqueue_id_2` (`timedeventqueue_id`),\n KEY `instance_id` (`instance_id`),\n KEY `event_type` (`event_type`),\n KEY `scheduled_time` (`scheduled_time`),\n KEY `object_id` (`object_id`),\n KEY `queued_time` (`queued_time`)\n) ENGINE=MyISAM AUTO_INCREMENT=452274466 DEFAULT CHARSET=utf8 COMMENT='Current Nagios event queue'
Table Create Table
Re: DB error
Nevermind - went to Google University and learned "SERIAL is an alias for BIGINT UNSIGNED NOT NULL AUTO_INCREMENT UNIQUE."
Re: DB error
It's hard to imagine a world without "Google University"...
Re: DB error
Isn't that the truth?! I wonder if there's an app for that.....lmiltchev wrote:It's hard to imagine a world without "Google University"...
Re: DB error
Unlocked by user request.
Did this not resolve the problem? What errors are you receiving now that it is changed to bigint?
Re: DB error
Post right after your 'alter table....' post
Re: DB error
So the error is still in nagios_timedeventqueue..
Can you run
the reason it is the same number is because that is the max size of the INT field you would have had before making the change
Can you run
echo "DESCRIBE nagios_timedeventqueue;"|mysql -pnagiosxi nagios
