my names conlala.
i was install nagios 4.0 and plugin 1.4 that is working.
to day add news switch Cisco 3560 with information :
1. files : switch.cfg
# SWITCH.CFG - SAMPLE CONFIG FILE FOR MONITORING A SWITCH
# NOTES: This config file assumes that you are using the sample configuration
# files that get installed with the Nagios quickstart guide.
# HOST DEFINITIONS
# Define the switch that we'll be monitoring
use generic-switch ; Inherit default values from a template
host_name Cisco-C3560 ; The name we're giving to this switch
alias Cisco C3560 Switch ; A longer name associated with the switch
address 172.16.251.4 ; IP address of the switch
hostgroups switches ; Host groups this switch is associated with
# HOST GROUP DEFINITIONS
# Create a new hostgroup for switches
define hostgroup{
hostgroup_name switches ; The name of the hostgroup
alias Network Switches ; Long name of the group
# SERVICE DEFINITIONS
# Create a service to PING to switch
use generic-service ; Inherit values from a template
host_name Cisco-C3560 ; The name of the host the service is associated with
service_description PING ; The service description
check_command check_ping!200.0,20%!600.0,60% ; The command used to monitor the service
normal_check_interval 5 ; Check the service every 5 minutes under normal conditions
retry_check_interval 1 ; Re-check the service every minute until its final/hard state is determined
# Monitor uptime via SNMP
service_description Uptime
check_command check_snmp!-C public -o sysUpTime.0
# Monitor Port 1 status via SNMP
service_description Port 1 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 1 -m RFC1213-MIB
service_description CPU Load
check_command check_cisco
# 'check_cisco' command definition
command_name check_cisco
command_line /usr/local/nagios/libexec/check_cisco -H 172.16.251.4 -C public -t cpu
when check config see errors :
Nagios Core 4.0.0-beta1
Last Modified: 05-24-2013
License: GPL
Reading configuration data...
Read main config file okay...
Checking services...
Error: Service check command 'check_cisco' specified in service 'CPU Load' for host 'Cisco-C3560' not defined anywhere!
Checked 4 services.
Checking hosts...
Checked 1 hosts.
Checking host groups...
Checked 1 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 1 contacts.
Checking contact groups...
Checked 1 contact groups.
Checking commands...
Checked 26 commands.
Checking time periods...
Checked 5 time periods.
Checked 1 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check...
Thank you read and support.
conlala
