Firstly I apologize if this has been asked and I haven't managed to find it.
I have a host I am monitoring for disk space and have set the following :-
Warning at 70% and critical at 90%.
I have setup email and sms and they seem to be working fine.
However
is there a way I could email myself (only) when the warning level is reached and email and sms myself when the critical level is reached.
I have a template setup but I seem to be able to call each one or both.
# SERVICE TEMPLATES NEW
#Generic service definition template - This is NOT a real service, just a template!
name netapp-service-email ; The 'name' of this service template
active_checks_enabled 1 ; Active service checks are enabled
passive_checks_enabled 1 ; Passive service checks are enabled/accepted
parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems)
obsess_over_service 1 ; We should obsess over this service (if necessary)
check_freshness 0 ; Default is to NOT check service 'freshness'
notifications_enabled 1 ; Service notifications are enabled
event_handler_enabled 1 ; Service event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
failure_prediction_enabled 1 ; Failure prediction is enabled
process_perf_data 1 ; Process performance data
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
is_volatile 0 ; The service is not volatile
check_period 24x7 ; The service can be checked at any time of the day
max_check_attempts 3 ; Re-check the service up to 3 times in order to determine its final (hard) state
normal_check_interval 10 ; Check the service every 10 minutes under normal conditions
retry_check_interval 2 ; Re-check the service every two minutes until a hard state can be determined
contact_groups email_admin ; Notifications get sent out to everyone in the 'admins' group
notification_options w,u,c,r ; Send notifications about warning, unknown, critical, and recovery events
notification_interval 720 ; Re-notify about service problems every hour
notification_period 24x7 ; Notifications can be sent out at any time
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
# Generic service definition template - This is NOT a real service, just a template!
name netapp-service-sms ; The 'name' of this service template
contact_groups sms_admin ; Notifications get sent out to everyone in the 'admins' group
notification_options u,c,r ; Send notifications about warning, unknown, critical, and recovery events
# CONTACTS
# Just one contact defined by default - the Nagios admin (that's you) # This contact definition inherits a lot of default values from the 'generic-contact'
# template which is defined elsewhere.
define contact{
contact_name nagios_email_admin ; Short name of user
use generic-contact ; Inherit default values from generic-contact template (defined above)
alias Nagios Email Admin ; Full name of user
email [email protected] ; <<***** CHANGE THIS TO YOUR EMAIL ADDRESS ******
define contact{
contact_name nagios_sms_admin ; Short name of user
use generic-contact-sms ; Inherit default values from generic-contact template (defined above)
alias Nagios SMS Admin ; Full name of user
email me@mysms ; <<***** CHANGE THIS TO YOUR EMAIL ADDRESS ******
# CONTACT GROUPS
# We only have one contact in this simple configuration file, so there is # no need to create more than one contact group.
define contactgroup{
contactgroup_name email_admin
alias Nagios Email Administrators
members nagios_email_admin
contactgroup_name sms_admin
alias Nagios SMS Administrators
members nagios_sms_admin
# SYSTEM CHECK SERVICE
use netapp-service-sms ; Inherit values from a template
host_name NetApp_FAS2240 ; The name of the host the service is associated with
service_description Vol Space - WEB IMAGES
check_command check_netapp_vol_cifs_web_images
