Failed convert mib path to snmptt.ini. (rc: 4)The sending server is sending traps to my nagios server, but the server I set up with the nagios trap wiz isn't getting them.
(I am trying to get traps from my hpsim management server)
[root@nagiosiskillingmep0111 ~]# tail -f /var/log/snmptt/snmptt.log
Sun Aug 4 22:51:18 2013 .1.3.6.1.4.1.11.2.17.1.0.58916872 Normal "Status Events" mybusted server - This special event can be generated by a user to 14 mybusted server Event Name: System is unreachable URL: http://simp02.one.org:280/mxportal/MxContextLaunch.jsp?systems=mybusted server&tool=System%20Page Event originator: mybusted server Event Severity: Critical Event received: 04-Aug-2013, 22:51:27 Event description: The current system is no longer reachable from the central management server, hardware status polling has marked this system as not responding " enterprises.11.2.17.2.5.Code: Select all
[root@LkennagiosT01 ~]# tail -f /var/log/snmptt/snmpttunknown.log
Value 10:
Ent Value 0: .1.3.6.1.2.1.1.5.0=this server1
Ent Value 1: .1.3.6.1.4.1.232.11.2.11.1.0=0
Ent Value 2: .1.3.6.1.4.1.232.3.2.2.1.1.20.2=Slot 1
Ent Value 3: .1.3.6.1.4.1.232.3.2.2.1.1.2.2=30
Ent Value 4: .1.3.6.1.4.1.232.3.2.2.2.1.1.2=2
Ent Value 5: .1.3.6.1.4.1.232.3.2.2.2.1.11.2=PA2270H9SVC30G
Ent Value 6: .1.3.6.1.4.1.232.3.2.2.2.1.12.2=524288
I used this docs to set up snmp: Nagios XI – Integrating SNMP Traps
