Hi ,
I want to monitor mounted volume on windows server, Please let me know if anyone has the solution for this.
Mounted Volume Monitoring
Re: Mounted Volume Monitoring
There are multiple ways to do this: NSClient++, WMI, or SNMP. There are probably other ways as well. Have you looked at the available wizards in XI?
Thanks for the reply.
I have used the passive check for this as below.
check_mount=CheckDriveSize ShowAll MaxWarnUsed=85% MaxCritUsed=90% Drive=F:\CADDaten\SWDAT2
Apart from above approach what are the other way we can configure the monitoring for mounted volume.
As noted above you can use any of those methods, if you would prefer to use active checks you could use check_nt, or NRPE via NSclient to attain the same information, this would be done via their disk checks.
Thanks for the information.
Let us know if you need help.
