HI,
1) In Bandwidth Usage report , we can generate the bandwidth utilization report for particular day ,month , year. Can we generate report based on mentioned timing for particular day .
ie : i want to generate reports for 2:00pm to 6 pm and need to send the report to customers.
2) In service status details, for switches , routers it shows real time bandwidth which is zoomable.
as it shows for very less period, can it be seen as we want .
ie: i want to see real time bandwidth for last two days or customized time which i want.
Bandwidth Report
Re: Bandwidth Report
You can specify time ranges using the Graph Explorer component. It is found at --> Home --> Graph Explorer --> Scalable Performance Graph.
