Nagios report
praveen.ks
Nagios report
Post by praveen.ks »
Which files is using to generate nagios reports in Nagios Core 3
Re: Nagios report
Post by slansing »
It depends on the report, are you asking what scripts are responsible for generating the reports? Or where the reports pull the information from?
praveen.ks
Re: Nagios report
In Nagios web access, we can take a reports for perticular object right.
which file is used to generate a reports
abrist
Red Shirt
Re: Nagios report
Post by abrist »
Reports are generated from the cgis.
