Hi All,
How can we see the data collected by this plugin in the NagiosGraph. This metric for the host doesn't show up in the NagiosGraph menu
Thanks in advance
Enable check_jmx for NagiosGraph
Re: Enable check_jmx for NagiosGraph
Under the service's page: Services > "Service Name" >
Is there any data listed under Performance Data?
If not, then the plugin does not return performance data, or you have incorrectly configured it. If it does not return performance data you would need to modify it to do so assuming it's license allows for modification "I believe all plugins do."
Please see:
http://nagiosplug.sourceforge.net/devel ... tml#AEN201
Please see:
No Performance data is being collected. I will check the URL you have posted. Thanks for the info
Great, that will help you figure out if it does return valid perf data, and if not, how to add it in.
