I copied this code from a post on the forum, hoping I could use this to see if I understand this macro.
This line comes from the posters command.cfg file:
command_line $USER1$/check_nt -H ~HOSTADDRESS$ -p 12489 -s <passwd> -v FILEAGE -l $ARG1$ -w $ARG2$ -c $ARG3$
Then in the services definition file there's this line:
check_command check_nt_fileage!"c:\\epoca\\temp\\nani.ftp" -w2 -c5
Is -w2 the value for $ARG2$ and -c5 the value for $ARG3$? And if that's correct, where is $ARG1$?
Trying to understand $ARG$
Re: Trying to understand $ARG$
In service definitions ARG's are separated by "!'s", hence, you would need to add additional "!'s" after each text string to denote the following text being set to the next numerically listed argument.
In other words, if you are trying to use all of those arguments you would define your service like so:
You should not need to have the added "-w2 or -c5" in there as that would double up the already hard coded values in the command, as well as not having the proper space after them.
check_command check_nt_fileage!"c:\\epoca\\temp\\nani.ftp"!2!5 -
sreinhardt
- -fno-stack-protector
Just as a warning, HOSTADDRESS should also have $s around it. Otherwise, the $arg#$ variables are used in check definitions to accept values from host or service check definitions. The arguments are separated by !, so in your example:
Command(check_nt): command_line $USER1$/check_nt -H ~HOSTADDRESS$ -p 12489 -s <passwd> -v FILEAGE -l $ARG1$ -w $ARG2$ -c $ARG3$
Service Check: check_nt!password!c:\path\to\file!30!45
Arg1 = password
Arg2 = c:\path\to\file
Arg3 = warning value
Arg4 = critical value
These are completely variable for each definition and you may use all, some, or none of them.
Arg1 = password
