I've notice the check_ports script that was directed to me by these forums (thank you!) is having issues on 52 port switches. It seems that the script is thinking that our 52 port switches have only 24 ports, or it is scanning the first 24 ports. As a result, it throws WARNINGS.
(replace $COMMUNITY and $ADDRESS with the actual values for one of your 52 port switches)
Post the output in code wraps.
