Integration Nagios with BMC Remedy
jesusmartinez800
Post by jesusmartinez800 »
Hi, we are implementing Nagios XI and Nagios Core with BMC Remedy, but I didn't find a good idea about it, only that Nagios could open a Ticket in Remedy in cases of failures but nobody said how it did. I heard about APIs and Addons to this integration, but I did not find it, If you have a procedure or any information about this integration, Addons or APIs, I will appreciate you, any good information.
Jesús M.C.
Technical Consultant.
Caracas.
Re: Integration Nagios with BMC Remedy
Post by slansing »
There are a number of pages on integration here:
https://www.google.com/search?q=nagios+ ... =firefox-a
Also, you could work towards setting up a event handler to open tickets, but a more likely solution would be a notification handler, a few pages in the list I sent you go down this path.
