monitoring routers and switch with nagios
barry1946
Post by barry1946 »
I have installed [b](nagios-3.5.0-1.el6.x86_64[/b] )on(centos 6.4 x64.) using yum
the purpose is to monitor the routers and switches .
but I am facing some problem:
1)my nagios.cfg is in /etc/nagios/ while all the tutorials including nagios officials say it exist in (/usr/local/nagios/etc/nagios.cfg directory)
anyway while i uncomment cfg_file=/usr/local/nagios/etc/objects/switch.cfg and enter the following configs
use routers
host_name cisco-7200
alias Cisco 7200
address 192.168.162.200
hostgroups routers
# Create a new hostgroup for switches
define hostgroup{
hostgroup_name routers
alias Network routers
I receive this error all the time:
Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
this is my rpm -qa | grep nagios
nagios-plugins-by_ssh-1.4.16-5.el6.x86_64
nagios-plugins-fping-1.4.16-5.el6.x86_64
nagios-plugins-smtp-1.4.16-5.el6.x86_64
nagios-plugins-mrtgtraf-1.4.16-5.el6.x86_64
nagios-plugins-sensors-1.4.16-5.el6.x86_64
nagios-plugins-breeze-1.4.16-5.el6.x86_64
nagios-plugins-cluster-1.4.16-5.el6.x86_64
nagios-plugins-tcp-1.4.16-5.el6.x86_64
nagios-plugins-procs-1.4.16-5.el6.x86_64
nagios-plugins-ssh-1.4.16-5.el6.x86_64
nagios-plugins-all-1.4.16-5.el6.x86_64
nagios-plugins-ntp-perl-1.4.16-5.el6.x86_64
nagios-plugins-load-1.4.16-5.el6.x86_64
nagios-plugins-log-1.4.16-5.el6.x86_64
nagios-plugins-disk-1.4.16-5.el6.x86_64
nagios-plugins-dummy-1.4.16-5.el6.x86_64
nagios-plugins-perl-1.4.16-5.el6.x86_64
nagios-plugins-snmp-1.4.16-5.el6.x86_64
nagios-plugins-rpc-1.4.16-5.el6.x86_64
nagios-plugins-mailq-1.4.16-5.el6.x86_64
nagios-plugins-nagios-1.4.16-5.el6.x86_64
nagios-plugins-ups-1.4.16-5.el6.x86_64
nagios-plugins-ldap-1.4.16-5.el6.x86_64
nagios-plugins-icmp-1.4.16-5.el6.x86_64
nagios-plugins-time-1.4.16-5.el6.x86_64
nagios-plugins-nrpe-2.14-3.el6.x86_64
nagios-plugins-http-1.4.16-5.el6.x86_64
nagios-plugins-ping-1.4.16-5.el6.x86_64
nagios-plugins-game-1.4.16-5.el6.x86_64
nagios-common-3.5.0-1.el6.x86_64
nagios-plugins-ircd-1.4.16-5.el6.x86_64
nagios-plugins-flexlm-1.4.16-5.el6.x86_64
nagios-plugins-file_age-1.4.16-5.el6.x86_64
nagios-plugins-dig-1.4.16-5.el6.x86_64
nagios-plugins-swap-1.4.16-5.el6.x86_64
nagios-plugins-dns-1.4.16-5.el6.x86_64
nagios-plugins-hpjd-1.4.16-5.el6.x86_64
nagios-plugins-oracle-1.4.16-5.el6.x86_64
nagios-plugins-mrtg-1.4.16-5.el6.x86_64
nagios-plugins-overcr-1.4.16-5.el6.x86_64
nagios-plugins-nwstat-1.4.16-5.el6.x86_64
nagios-plugins-ide_smart-1.4.16-5.el6.x86_64
nagios-plugins-users-1.4.16-5.el6.x86_64
nagios-plugins-wave-1.4.16-5.el6.x86_64
nagios-plugins-pgsql-1.4.16-5.el6.x86_64
nagios-plugins-ntp-1.4.16-5.el6.x86_64
nagios-plugins-dhcp-1.4.16-5.el6.x86_64
nagios-plugins-mysql-1.4.16-5.el6.x86_64
nagios-plugins-nt-1.4.16-5.el6.x86_64
nagios-devel-3.5.0-1.el6.x86_64
nagios-plugins-1.4.16-5.el6.x86_64
nagios-plugins-disk_smb-1.4.16-5.el6.x86_64
nagios-plugins-real-1.4.16-5.el6.x86_64
do u have any idea which helps?
thanks in advance?
Re: monitoring routers and switch with nagios
Post by slansing »
Please run the following and share the output "wrap it with the 'CODE' tool within the reply page."
Be sure to alter the paths to the bin and the .cfg if they are different in your installation:
/usr/local/nagios/bin/nagios -v /etc/nagios.cfg
Cited:
http://nagios.sourceforge.net/docs/3_0/ ... onfig.html
barry1946
Post by barry1946 »
Dear thanks for answering :
[root@nagios local]# echo $PATH
:/usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin:/etc:/usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin:/etc:/usr/local/nagios/bin/:/usr/local/nagios/bin/nagios
[root@nagios ~]# cd /usr/local/
[root@nagios local]# ls
bin etc games include lib lib64 libexec sbin share src
[root@nagios local]# /usr/local/nagios/bin/nagios -v /etc/nagios.cfg
-bash: /usr/local/nagios/bin/nagios: No such file or directory
this directory does not exist .
for me it is like this :
[root@nagios nagios]# cd /etc/nagios/objects/
[root@nagios objects]# ls
commands.cfg contacts.cfg localhost.cfg printer.cfg switch.cfg templates.cfg timeperiods.cfg windows.cfg
Post by slansing »
As mentioned you will need to change the directories to where you have those files at. So, you will need to locate your nagios bin and the location of your nagios.cfg which I believe you posted.
barry1946
Post by barry1946 »
I think this is what you mean :
I did like this:
[root@nagios objects]# whereis nagios
nagios: /usr/sbin/nagios /etc/nagios /usr/lib64/nagios /usr/include/nagios /usr/share/nagios
then I added these to the path I also added /etc to the path then i couls get some answers:
then
[root@nagios objects]# /usr/sbin/nagios -v /etc/nagios.cfg
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Error: Cannot open main configuration file '/etc/nagios.cfg' for reading!
Error processing main config file!
the problem after restarting the service still exist!
abrist
Red Shirt
Post by abrist »
there is a good change the nagios.cfg is located inside the /etc/nagios directory:
Try:
/usr/sbin/nagios -v /etc/nagios/nagios.cfg
barry1946
Post by barry1946 »
the problem solved.
i should have enter the router configuration data in switch.cfg file not the nagios.cfg file
thanks for your responses anyway
