custom bash script
ddk
custom bash script
Post by ddk »
Hi all!
I wrote custom bash script for Nagios Core, but in web interface it returns:
Current Status:	WARNING
Status Information:	(null)
while in console it returns normal results, like:
CRITICAL: 2
Exit codes are from manual:
if [ $RESULT -ge $WARN ] && [ $RESULT -lt $CRIT ]; then
	    echo "WARNING: $RESULT warn:$WARN; crit:$CRIT $ADDINFO"
	    exit 1
	elif [ $RESULT -ge $CRIT ]
	then
	    echo "CRITICAL: $RESULT  warn:$WARN; crit:$CRIT $ADDINFO"
	    exit 2
	else
	    echo "OK - warn:$WARN; crit:$CRIT"
	    exit 0
	fi
whats wrong?
Re: custom bash script
Post by slansing »
Can you share the entire script here via an attachment? That would help greatly!
ddk
Post by ddk »
here it is
mysqlcheck.sh
(1.74 KiB) Downloaded 335 times
abrist
Red Shirt
Post by abrist »
ddk wrote:while in console it returns normal results, like:
CRITICAL: 2
Shouldn't it be returning the whole string, not just the $RESULT but also $WARN, $CRIT and $ADDINFO?
ddk
Post by ddk »
CRITICAL: 2
it's copy-paste fail, sorry.
it is returninng full string as it's writing in script
abrist
Red Shirt
Post by abrist »
Are you running from the cli as the "nagios" user?
ddk
Post by ddk »
# su nagios
bash-4.1$ /usr/lib64/nagios/plugins//check_mysql_query_custom -H 192.168.0.1 -d DB -w 1 -c 2 -u USER -p PASS -t 1
/bin/bash: /root/.bashrc: Permission denied
CRITICAL: 2  warn:1; crit:2 ID: 5 Desc:192.168.0.2 Date: 2013-08-19 20:07:17
abrist
Red Shirt
Post by abrist »
Lets just make sure that it works without the bash error:
On teh remote host:
su nagios
cd /home/nagios/
ddk
Post by ddk »
abrist wrote:Lets just make sure that it works without the bash error:
On teh remote host:
su nagios
cd /home/nagios/
there is no such directory
'nagios' home dir is - /var/spool/nagios
so:
# su nagios
bash-4.1$ cd ~/
bash-4.1$ pwd
/var/spool/nagios
abrist
Red Shirt
Post by abrist »
Maybe you are having an environment variable issue. What are your environment variables?
env
