hi,
Can you help me out with the advance web based applications monitoring .
Is selenium will help me out in this , please give me the list of software to integrate or any links which it can help me out.
Web based Application
Re: Web based Application
What specifically are you looking to check against? Selenium provides great web-user based testing of sites.
i just want to know where can i find the advance monitoring for Web based applications,
except the parameters from the wizard we get how to monitor advance monitoring.
i still not got the list of advance parameters list
We still need more information, advanced monitoring is a very broad term. Which wizard are you using?
Please go into more depth on the above statement.i still not got the list of advance parameters list
