Putty "Access Denied"
LCStek
Post by LCStek »
I am setting up a Nagios XI Standard trial and using the guide and the "additional information link" from http://exchange.nagios.org/components/c ... 1&cf_id=24. I have set the passwords in the places indicated in these documents and I can log in to the web interface as well as the console in VMware. I am trying to follow the steps that reference using Putty over SSH port 22, But, Putty says "access denied" when I try logging in using the nagios admin user. What credentials is it looking for? I am not sure why I cannot connect via Putty. Which credential would I need to reset or use in order to connect?
Re: Putty "Access Denied"
Post by slansing »
Putty would allow access to the server itself so you would need to use credentials for that server. By default the root user is set to:
User:
root
Pass:
nagiosxi
LCStek
Post by LCStek »
OK thanks I had not made the connection that I needed to use Root. How can I change the Root password from the default?
abrist
Red Shirt
Post by abrist »
Once logged in as root, try:
passwd
It will ask you to enter the new pass twice for confirmation. Don't forget it, otherwise we will need to boot from a livecd to reset it!
