pnp4nagios-0.6.21 03-24-2013
kalyandrug
Post by kalyandrug »
Not able to configure pnp4nagios. After executing configure file out put as follows
General Options:
Nagios user/group: CONTENT REMOVED
Install directory: /usr/local/pnp4nagios
HTML Dir: /usr/local/pnp4nagios/share
Config Dir: /usr/local/pnp4nagios/etc
Location of rrdtool binary: /usr/bin/rrdtool Version 1.2.27
RRDs Perl Modules: FOUND (Version 1.2027)
RRD Files stored in: /usr/local/pnp4nagios/var/perfdata
process_perfdata.pl Logfile: /usr/local/pnp4nagios/var/perfdata.log
Perfdata files (NPCD) stored in: /usr/local/pnp4nagios/var/spool
Web Interface Options:
HTML URL: http://localhost/pnp4nagios
Apache Config File: /etc/httpd/conf.d/pnp4nagios.conf
Review the options above for accuracy. If they look okay,
type 'make all' to compile.
but if I got to /usr/local/ I am not seeing pnp4nagios directory . Please help me in this regard.
Re: pnp4nagios-0.6.21 03-24-2013
Post by slansing »
Looks like you should be talking to the company who's username and password you use for your account as they would need to do the modifications necessary for this to work on another monitoring solution. Closing thread.
