Hi All,
We are running Nagios XI 2011R1.9 and for the notification we have set up an smtp server (smtp.xxxx.com) and connecting to the port 25 and we are able to get all the alerts related to any host or service but when we are trying to send an test mail it is throwing an error ...and we are not getting any test mail.
Please find the below errors
ADDRESSES Array ( [0] => Array ( [name] => [email] => [email protected] ) ) SMTP Error: Could not connect to SMTP host.
Test Email Settings
A test email was sent to [email protected]
Mailer said: SMTP Error: Could not connect to SMTP host. (method=smtp;host=smtp.xxxx.com;port=25;security=none)
An error occurred sending a test email!
Use this to test your mail settings.
An email will be sent to: [email protected]
Change your email address
Please suggest me if anything i need to change/modify in nagios xi configuration. or do i need to make any changes to the smtp server ?(My understanding is since we are getting the alert for services that means Nagios XI is already in the relay list of the smtp server i am confused......).
Thanks in advance.
With Regards,
Bijay Ojha
not able to send the test mail but getting all alert
sreinhardt
- -fno-stack-protector
Re: not able to send the test mail but getting all alert
Well, yes it does, and no it does not mean that nagios is on the relay list. Lets start with a few things:
1) Are these users or contacts that are getting notifications?
2) What notification handler are you using?
3) Please run the following command and return it to me:
nmap -p 25 smtp.xxxx.com (your mail server)
Hi sreinhardt,
Thank you for the replay.
Please find below the answer to the questions
1. Not sure whether all the users or contact are getting alert but i am sure some of the users(including me ) are getting the alerts.
2. I have checked the contact template and below are the notification handlers getting used.
host_notification_commands xi_host_notification_handler
service_notification_commands xi_service_notification_handler
3.[root@nagiosvm01 ~]# nmap -p 25 smtp.xxxx.com
Starting Nmap 4.11 ( http://www.insecure.org/nmap/ ) at 2013-08-26 01:00 EDT
Warning: Hostname smtp.xxxx.com resolves to 2 IPs. Using 10.111.20.128.
Interesting ports on 10.111.20.128:
PORT STATE SERVICE
25/tcp open smtp
Nmap finished: 1 IP address (1 host up) scanned in 0.202 seconds
With Regards,
Bijay Ojha
PORT STATE SERVICE
25/tcp open smtp
With Regards,
Bijay Ojha
Be sure to follow these guidelines as they can cause the problem you are experiencing:
source: http://assets.nagios.com/downloads/nagi ... ations.pdfIf you are using Users, which are also Contacts (you've
added a Contact to them), select:
xi_host_notification_handler (under "Manage Host
Notification Commands")
and
xi_service_notification_handler (under "Manage
Service Notification Commands")
If you are using Contacts only, select:
notify-host-by-email (under "Manage Host
and
notify-service-by-email (under "Manage Service
Hi slansing,
Thank you for the replay,
I have verified the contact definition and the handlers are setup properly by considering me (i am a user and contact as well) but again throwing the same error.
please find my contact and contact template definition.
define contact {
contact_name bojha
alias Bijay Ojha
host_notifications_enabled 1
service_notifications_enabled 1
host_notification_period bojha_notification_times
service_notification_period bojha_notification_times
host_notification_options d,u,r,f,s
service_notification_options w,u,c,r,f,s
email [email protected]
use xi_contact_generic
Contact Template
define contact {
name xi_contact_generic
contactgroups xi_contactgroup_all
register 0
# Contacttemplate configuration file
Please let me know if i have to check anything else.
With Regards,
Bijay Ojha
define contact {
contact_name bojha
alias Bijay Ojha
Contact Template
define contact {
register 0
With Regards,
Bijay Ojha
Can you send a screenshot of Admin > Manage Email Settings, you can blank out anything you do not wish to share. What MTA are you using for the XI server? Just the defaults that are on the system when it is ran as a VM or installed over a basic Centos/RHEL server that has not been edited by your company?
Hi slansing,
please find attached the screen shoot.
I am not sure whether it has been edited or not ? because this instance was there even before i joined this company, Could you please let me know where i have to check for the information you have asked ?
One observation i did is, created one contact and set up the alert, the contact is not getting the alert but i created one user for the same and during the user creation checked to create a contact then he is getting the alert. in both the case i had used the same mail id
With Regards,
Bijay Ojha
With Regards,
Bijay Ojha
Well then your mailserver and MTA should be fine. Are you sure the contacts are set to use the proper host and service notification handlers? If you created a User + Contact then it would be using the xi_notify* commands. The contacts by themselves should only ever use the notify-* commands.
Hi slansing,
Thank you for your replay.
Yes i am sure and double checked the notification handler for the contact for host and service command but the alerts are not coming. i don't understand why it is not coming, please suggest me if i have to check anything else ?
Thanks in advance..
With Regards,
Bijay Ojha
Thanks in advance..
With Regards,
Bijay Ojha
sreinhardt
Does your local MTA happen to have any restrictions from the apache user sending mail vs the nagios user? If I am understanding correctly, alerts from issues are being sent, but using the test mail button is not working, right?
