Hello all
i need your help to monitor with nagios some un-regular processes :
1. logstash
2.ora_smon
3.elasticsearch
i'm search for a lot of scripts but because those services are nor regular the nagios return that he didn't found any process running on the server.
my second issue is that i want to monitor on REMOTE server if the file dummy.html (on specific directory) is there.
plz help me
Amit
Monitor files and un-regular services
Re: Monitor files and un-regular services
Not quite sure what you mean by "un-regular" services/processes. Are they services or processes? And what makes them irregular?
What plugins have you tried? You can use this plugin to check if a file is in existence on a Linux system:
http://exchange.nagios.org/directory/Pl ... nt/details
