I just upgraded Fusion to 2012r1.6. The upgrade instructions PDF said to use
wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
But after installing that, I found that it was the old version 1.5 from January 13th.
I was able to get 1.6 from the download directory and it installed without any
major problems.
I guess the 'latest' file could be cached somewhere, but if not, it needs to be updated.
Fusion Upgrade to 2012R1.6
Re: Fusion Upgrade to 2012R1.6
It should be updated in around 15 minutes, thank you.
