Still getting Alerts while removed hosts
Hi Team,
I have been removed two hosts from Nagios xi with the help of CCM for last week. but still i am getting alerts about those hosts. while i rechecked couple of time with the help of command mode in /usr/local/nagios/etc/hosts and /usr/local/nagios/services. but there are no any existence of those hosts.
Please help me as soon as possible.
sreinhardt
- -fno-stack-protector
Re: Still getting Alerts while removed hosts
What version of XI are you currently running? Can you pm one of us with the latest good config snapshot, and tell us what host\services are having issues.
Nagios XI 2012R2.2 is a version of Nagios xi.
Actually before 2 weak, i removed the two host (RADshare 27 and 172.25.24.27) with the help of CCM. but still getting Alerts of them. while i also removed the configuration files from /usr/local/nagios/etc/hosts and /usr/local/nagios/etc/services .
Alerts are following:
Nagios URL: http://169.131.130.107/nagiosxi/
***** Nagios XI Alert *****
Notification Type: PROBLEM
Host: 172.25.24.27
State: DOWN
Address: 172.25.24.27
Info: CRITICAL - 172.25.24.27: rta nan, lost 100%
Date/Time: 2013-08-28 04:58:58
Host: 172.25.24.27
State: DOWN
This is strange. I don't see these two hosts in your configs. You shouldn't be getting alerts. Have you tried restarting services?
Do you see any config errors, when you run the Write Config Tool?
service nagios stop
killall -9 nagios
service ndo2db stop
service ndo2db start
service nagios startCode: Select all
CCM->Tools->Write Config FilesBe sure to check out our Knowledgebase for helpful articles and solutions!
I restarted nagios service couple of times but not ndo2db service. so, as of now i have executed all command what you have mentioned.
and following are the output when i do write Config Files. i don't think it's showing any kind of error.
Write host configurations ...
Host configuration files successfully written!
Write service configurations ...
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!
Can you try to re-create that host with the same information you are receiving in the notifications? Then apply configuration? I'm curious to see if it errors out.
Actually the two hosts(RADshare 27 and 172.25.24.27) have same host address which i removed. so,is that caused this problem?
Yes that would have caused an issue, is that present elsewhere?
It's possible. BTW, when you ran the Write Config Tool, did you click only on the "Write" button? Do you get any config errors, when you click on the "Verify" button (warnings are OK)?
When i run this command: grep -r "RADshare 27" /usr/local/nagios
it still presence in following area:
/usr/local/nagios/var/archives/nagios-06-02-2013-00.log:[1370059200] CURRENT SERVICE STATE: RADshare 27;Explorer;OK;HARD;1;Explorer.EXE: Running
/usr/local/nagios/var/archives/nagios-06-02-2013-00.log:[1370059200] CURRENT SERVICE STATE: RADshare 27;FaxComm;OK;HARD;1;FAXComm V2.0b_80.exe: Running
/usr/local/nagios/var/archives/nagios-06-02-2013-00.log:[1370059200] CURRENT SERVICE STATE: RADshare 27;IIS Web Server;OK;HARD;1;W3SVC: Started
/usr/local/nagios/var/archives/nagios-06-02-2013-00.log:[1370059200] CURRENT SERVICE STATE: RADshare 27;Memory Usage;OK;HARD;1;Memory usage: total:5971.96 Mb -
is It creating problem from here?
and when i ran the Write Config Tool, and cleck "Write" button, there is no any errors only one warning is there
