I was trying to add a custom Citrix icon to a service template, but I can't manage to make it work. Uploaded the files to /usr/local/nagios/share/images/logos
When I choose any icon that already existed it works. So maybe it's a problem with my icon format or extension. it is 40 x 40 pixels and I tried it with .png and .gif extension but didn't work for either one. I'll upload them here. I also checked the rights, but they seem ok. Also tried emptying my IE cache.
Tx fr any tips.
Willem
Custom icons
Custom icons
Nagios XI 5.8.1
https://outsideit.net
Re: Custom icons
What are the permissions on the file? If it's not owned by nagios, run the following command:
chown nagios.nagios /usr/local/nagios/share/images/logos/citrix.pngBe sure to check out our Knowledgebase for helpful articles and solutions!
Re: Custom icons
Well Nagios was not the owner, but none of the icons in the logos folder has nagios as owner. They all have root as owner in fact and it works for them. I changed the owner anyway for the icon I'm trying to use, but it's still not working.
Nagios XI 5.8.1
Re: Custom icons
I believe you will have to place the image in:
I just tested this and it works fine with your png.
/usr/local/nagiosxi/html/includes/components/nagioscore/ui/images/logos/Re: Custom icons
Can you go to the CCM->Service Templates-><your template>->Modify->Misc Settings and post a screenshot of this page?
Re: Custom icons
Maybe I placed the image in the wrong location, based on the documentation of CCM. See screenshot...
But even after copying the image to /usr/local/nagiosxi/html/includes/components/nagioscore/ui/images/logos/ and changing the owner to nagios, it's still not loading.
Grtz
Grtz
Nagios XI 5.8.1
Re: Custom icons
Ok, now it seems to work suddenly, did some stuff, httpd restart. Or maybe it wasn't in my cache or something. Anyway, it works! Thanks!
It's a bit confusing the documentation seems wrong, but I guess the documentation belongs to Nagios Core so it's not possible to update it somehow..
Nagios XI 5.8.1
Re: Custom icons
I'm glad your issue has been resolved! Locking the post.
