System time and php time are not matching
INFINITT
Post by INFINITT »
I know this topic is allready discussed but I can't install NTP on my Nagios Server so I need an another way for fixing this issue. :(
As you can see in the attached image my systemtime and my timezone are correct. But you also can see the differnce between the systemtime and the PHP time.
Europe/Berlin is +1 (GMT).
Due this issue I am getting eMails and reports from the future. :P
Where can I set the GMT?
Where or how can I set the PHP time?
Or is there a way to syncronize both times?
Thanks a lot for your help and support in advance :D
:D Nagsios XI newbie :D
Re: System time and php time are not matching
Post by slansing »
We can certainly help can you please run the following?:
date
grep date.timezone /etc/php.ini
And send us the output?
The best way to sync is with ntp, however you can change the timezones in several other places.
This is a good, short guide to changing your system time:
http://www.timgalyean.com/posts/to-chan ... me-centos/
INFINITT
Post by INFINITT »
at first THX for your help.
After chaniging my system time like this:
[root@localhost ~]# date
Mon Sep 2 08:52:41 EDT 2013
[root@localhost ~]# cp /etc/localtime /etc/lokaltime.bak
[root@localhost ~]# rm -f /etc/localtime
[root@localhost ~]# ln -s /usr/share/zoneinfo/europe/berlin /etc/localtime
Mon Sep 2 12:54:21 UTC 2013
my output for
date is:
and the putput for
grep date.timezone /etc/php.ini is:
[root@localhost ~]# grep date.timezone /etc/php.ini
; http://www.php.net/manual/en/datetime.c ... e.timezone
; date.timezone = America/New_York
date.timezone = Europe/Berlin
I've already tried to change my PHP Time but nevertheless the difference between the PHP-Time and the system time are 2h.
Thx in advance for your support :D
abrist
Red Shirt
Post by abrist »
Did you change the clock settings as well?
http://assets.nagios.com/downloads/nagi ... m_Time.pdf
INFINITT
Post by INFINITT »
yes. I already changed the Zone to ZONE="Europe/Berlin" but still the same issue. (Time difference +2 h)
abrist
Red Shirt
Post by abrist »
This is odd. Are you sure those files are different?
diff /usr/share/zoneinfo/Europe/Berlin /usr/share/zoneinfo/UTC
ls -la /usr/share/zoneinfo/Europe/Berlin
ls -la /etc/localtime
