Hi Support,
OS: CentOS release 6.4
64bit
Using VMWare Image
I am using the Website monitoring wizard to monitor our website, and I understand that there are some statistical data that we can get from this, like availability, performance.
I am able to see the monthly performance graph, is there any way to export out the performance statistic? I would like to get a report for this. Is it possible?
Rudy
Website HTTP Check, how to get monthly performance data?
Re: Website HTTP Check, how to get monthly performance data?
If you do have performance data from a month back you can use the graph explorer to see it, download it, or print it.
The graph explorer is located at Home > Graph Explorer > Scalable Performance Graphs.
Hi Slansing,
Thanks, I think your instruction satisfy our requirement.
Rudy
Rudy
