Hello all,
We have an issue on our servers sometimes where nagios runs a command, but it will exit critical with this message:
Message=CRITICAL - Socket timeout after 10 seconds
I don't mind that it exits with the socket timeout. In fact I want it to do that so it doesn't get stuck forever. BUT i don't want it to exit critical. I need it to exit warning or error or something other than critical.
How can i fix this? for example, if i am executing a command using check_by_ssh, it there some option or config parameter i can change so that if it times out it will only exit with a warning rather than a critical?
I can't have it exit critical because we have another application that is scanning Nagios searching for critical errors, but this is not something we want the application to pickup (hence why i want to switch it to warning)
Thanks in advance!
Service Check Timeout - Exit Warning Instead of Critical
Re: Service Check Timeout - Exit Warning Instead of Critical
First of all, you may be able to increase the timeout of the check:
Second, take a look at the negate plugin, for altering return codes:
http://nagiosplugins.org/man/negate
http://nagiosplugins.org/man/check_by_ssh-t, --timeout=INTEGER
Seconds before connection times out (default: 10)
