I just noticed our time in the last checked column is 8 hours off.
I thought i had fixed this before, the current time and the time in the performance graphs are correct.
Here is my time from system Profile:
Date/Time
PHP Timezone: America/New_York
PHP Time: Tue, 03 Sep 2013 08:47:08 -0400
System Time: Tue, 03 Sep 2013 08:47:08 -0400
Services last check time
benningtonr
Reason: Do not make double posts, just edit your previous post if you are the last poster.
Re: Services last check time
Is it possible for you to restart the full nagios server? This has fixed this problem for others in the past. Let us know.
benningtonr
i will restart in a few and post the results
Great, Let us know.
benningtonr
That did it, thanks
