I installed the trial version NagiosXI on CentOS 5.5, I am assessing the tool to manage the purchase and assemble 50,000 services, just do not know if the trial version have any limitations with the full version
1)By default, this built-in monitoring the local machine, but the graphics option is not throw me any information (attached photo)
2)I'm used to mainstream servers using the console, this new interface option given me a bit complicated, you can continue working the old way nagios?
3)By accessing Nagios Core http://ip/nagios me for a password, the login credentials entered correctly but since the option NagiosXI says Core Config Manager and credentials are rejected, any idea why this problem be?
thank you very much
HELP & QUESTION
Hector Roman
HELP & QUESTION
Re: HELP & QUESTION
Take a look at the steps for getting started in this guide:
http://assets.nagios.com/downloads/nagi ... itialsetup
