Real time CPU Usage
00_kl250
Real time CPU Usage
Post by 00_kl250 »
All,
I'm wondering if it's possible to monitor CPU usage real time instead of a 5 minute average. In my windows.cfg folder I have the following configuration for cpu load:
hostgroup_name tt-servers,windows-servers
service_description CPU Load
check_command check_nt!CPULOAD!-l 5,80,90
It's set to warn at 80% and critical at 90% for 5 min average but I want real time so I can catch CPU spikes. Can anyone help?
Thanks!
sreinhardt
-fno-stack-protector
Re: Real time CPU Usage
Post by sreinhardt »
Likely the best way to do this would actually be snmptraps, as they would be generated via the remote system and indexed at all times. Even if you were to monitor every 1 minute or take the exact rate at 5 minute intervals you are likely to miss spikes. The only other option would be another passive check of some sort, however most, like nagios core, run on schedules and not realtime.
