NRPE CheckCounter for memory reads/sec
Brick
Post by Brick »
I am trying to setup a NRPE counter to read the Memory Reads/sec and Memory Faults/sec using the following command-
./check_nrpe -u -H 10.210.26.31 -c CheckCounter -a "Counter=\\Server\\Memory\\Page Reads/sec"
But I get the following return-
CRIT: Counter not found: \Server\Memory\Page Reads/sec: -1073738823: The specified counter could not be found.
I do have another CheckCounter command which is running fine-
./check_nrpe -u -H 10.210.26.31 -c CheckCounter -a "Counter=\\Server\\Bytes Total/sec" ShowAll
So I suspect its a syntax error with the actual command rather than a problem with nrpe or perfmon... But I have tried every iteration of server\memory\ that I can think of and still no luck!
Re: NRPE CheckCounter for memory reads/sec
Post by slansing »
Have you tried running the counter check without \Server\ in the string? What Windows version are you running this against? And what NSclient version is installed on it. I'll be able to test it on my end once we have that info.
Brick
Post by Brick »
Cheers slansing, it all worked fine once I removed the \server\
