System status Issue
rdhall01
System status Issue
Post by rdhall01 »
After upgrading to the latest version Nagios XI 2012R2.3 The system status componenet has a spinning icon no status displayed! I tried to restatrt nagios from the command line to reolve, but no luck any ideas of how to resolve it!
Information and alerts at the bottom of the gui also just spinning!
abrist
Red Shirt
Re: System status Issue
Post by abrist »
Is cron running?
service crond status
If not, start it:
service crond start
If so, restart it:
service crond stop
ps -aef|grep cron
service crond start
rdhall01
Post by rdhall01 »
I dont thin that resolved it but I think the other symptoms i believe to be red herring / false alarm after looking closer to the issue the applying configuration
waiting for configuration verification...........
was taking more than 5 mins to fail then I get
Applying Configuration
Command submitted for processing...
Waiting for configuration verification........................................
Configurations failed to write to file.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
View a snapshot of this configuration error
I go to
Monitoring Configuration Snapshots
The latest configuration snapshots of the XI monitoring engine are shown below. Download the most recent snapshots as backups, or get vital information for troubleshooting configuration errors.
Date Snapshot Result File Actions
2013-09-10 15:32:53 Config Ok 1378841573.tar.gz Download View OutputRestore
2013-09-10 15:32:44 Config Ok 1378841564.tar.gz Download View OutputRestore
2013-09-10 14:14:48 Config Ok 1378836888.tar.gz Download View OutputRestore
2013-09-10 14:06:25 Config Ok 1378836385.tar.gz Download View OutputRestore
2013-09-10 12:36:59 Config Ok 1378831019.tar.gz Download View OutputRestore
2013-09-10 11:20:59 Config Ok 1378826459.tar.gz Download View OutputRestore
2013-09-10 10:35:17 Config Ok 1378823717.tar.gz Download View OutputRestore
2013-09-10 10:32:15 Config Ok 1378823535.tar.gz Download View OutputRestore
2013-09-10 10:30:00 Config Ok 1378823400.tar.gz Download View OutputRestore
2013-09-09 20:11:02 Config Ok 1378771862.tar.gz Download View OutputRestore
if I look at the latest config no errors or warnings included is tthe output
abrist
Red Shirt
Post by abrist »
The verification you attached is clean. You may be hitting the limits set in you php.ini file. Lets check the current settings, please post the output of:
grep "memory_limit\|max_execution\|max_input" /etc/php.ini
rdhall01
Post by rdhall01 »
max_execution_time = 30 ; Maximum execution time of each script, in seconds
max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
memory_limit = 128M ; Maximum amount of memory a script may consume
abrist
Red Shirt
Post by abrist »
Lets increase these values. Change them to:
max_execution_time = 60 ; Maximum execution time of each script, in seconds
max_input_time = 90 ; Maximum amount of time each script may spend parsing request data
memory_limit = 512M ; Maximum amount of memory a script may consume
Then restart apache:
service httpd restart
rdhall01
Post by rdhall01 »
values changes and httpd restarted
abrist
Red Shirt
Post by abrist »
Go ahead and try to apply config once again.
rdhall01
Post by rdhall01 »
winner that resolved the issue thx
