Parent / Child Relationship for nagiosxi
rdhall01
Post by rdhall01 »
Is there a component or addon that will show all the parent / child relationships that are configured in nagios outside of the nagios status map? or is there a way to get the information?
sreinhardt
-fno-stack-protector
Re: Parent / Child Relationship for nagiosxi
Post by sreinhardt »
The minemap is presently the only thing that works soley off parent\child relation. It will however show the relationships between the hosts as you likely need.
rdhall01
Post by rdhall01 »
The minemap does show parent / child relationship, That i can see if I go to nagios instead of nagiosxi go to map - balanced tree I can sort of see it, but was looking for something a little easier to display the relationship( this refreshess wqy to quick)! Any other ideas would be helpful
The Hypermap works well. You can also use NagVis. You will have to modify the map view by increasing the "childLayers", depending on the complexity of the "parent/child" relationships you have defined (I believe the default value is set to "2").
