a commercial break from the " my snmptt is busted" show
When I run a backup on my Production server, it completes with no errors.
When i scp the tar file to my secondary server, and then run the restore script, I get an error saying "blah blah you are screwed" unexpected end of file"
This was working fine up until a few weeks ago.
I am including the scripts I use for your viewing pleasure
nagiosxi backup issue
Reason: removed files for passwords
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
sreinhardt
- -fno-stack-protector
Re: nagiosxi backup issue
First note, and could be from uploading to the servers, they are in dos format not unix. Otherwise nothing is screaming at me that its wrong, what line is the error at?
Edit: You are missing a semi-colon on 86, 67, 53, 42, 18 and 7, yep in revers order. Otherwise there are just a few missing spaces between ; and then in a few places but still nothing major or that should cause an issue.
